Sounds logical , Thanks
Today the VSV took a crap on me. Had to take vacuum off of the cruisecontrol to get home. It'll be hard to get to that vsv to replace it :/
One more thing the car started doing (I changed back to the old config, cause I had no time to tune the new, and I don't think that I've changed anything there) - On certain throttle setting and rpm and gear it starts bogging- ~9 AFR. Well, going WOT in 2nd gear @ 1500 rpm isn't a problem I guess, you don't do that often
and I've probably never tried it before, but what bugs me is that it did it in first gear today, numerous times, so I don't think that's coincidence. Just goes very rich and starts bogging. Just at about 1200-1500 rpm. Could there be anything else off besides the VE Table? Open loop comes in after those ~3400rpms only and TPS position is irrelevant?
Tried to lover Boost psi set and psi start today. With set 8 and start 3 it cut my fuel just about at the end of 2nd gear where the boost spiked (for a long time) onto 10psi. How to get the boost controller more into grip? The EBC manual says only lover the start psi...but soon I can't go any lower anymore? I think I need to read throttletech more...
JimR, how's (when? and how much
) that stock ct spooling? Airflow mods? I have a just rebuilt stock ct26 lying around that I wanted to install on my car before I got this car
and now I'm thinking of selling the 60.1 and putting the stock one into use. I start flying at 3.5k rpms and that's actually a joke...
I want instanteneous boost, but also would like, approximatelly, the power I have now
Now it also has 3" IC with pipes but I'll install 2,5" there for shorter lag (and besides, 3" is way too big I guess...)
