supranaut said:My car was Larry's testbed for the SPXXGT project and I have no probs with the MAFT....25psi and no fuel cut.
Dziuggy said:as i posted before it was fine on mine up to 25 psi on sp61gt, and ct26 now i have sp63 w/ external gate and i am hitting FC @ 1.1bar.
i just picked up HKS FCD, but i am a little bummed as all the things go on the same wires (i have maft, safc2 and now FCD and they all use airflow signal / rpm + pwr/gnd i woried if tha t will not be too much for my harness to handle. also FCD uses same technology as maft for fuel cut (clamp HZ) so would it be posible that it will mess up safc setings????
zig
90suprat said:Ziggy, since you have a SAFC, I would probaly recommend you ZERO out the settings on the MAFT and use the SAFC to tune bro, that way the signals don't conflict or try to cancel each other out, with that said a FCD + SAFC= impossible to tune, you will soon find out... aight peace
dbsupra90 said:didnt i say that on page 1? i guess noone ever reads my posts.
what you could try is hooking up the afc b/w the maf and maft. all youd have to do is move one wire and set afc for hot wire.
but im not a fan of clamping the output, i think leaving fcd off and tuning w/ the afc alone after the maft would be the best way to go. ive ran 25psi on the pt61 w/o fuel cut.
