Having problems with the maft pro reading the LC-1 wideband. Although I know the wideband works because when hooked up to the labtop directly it will read it. Any one have advice??
pimptrizkit said:red 12v switched power,
blue connected to ground with white & green wire tied into it,
black going to the led, then the switched connected to it before ground,
analog 1 yellow, is hooked up to the ecu on the ox wire, and analog 2 is the brown wire hooked up to the maft pro through the orange wire.
pimptrizkit said:every thing was working legit i hooked up the yellow wire to ox, and fixed the led i had it grounded wrong so it wouldn't flash and show it was operational but the maft pro read the signal fine,
i fixed the ground issue, it worked on the maft pro for probaly only 30 minutes after words then shows no signal.
what gets meeh is, i hooked up the ox wire to analog one, it goes rich,
and the maft pro was reading, it was showing 7/8 and then crapped out,
i hooked up the laptop and monitor the a/f using logworks, and it was reading some where around 12 a/f, i leaned the main scale out 20 percent, barely got the logworks to climb to 14's, 30% pushed it into the 15's,
i have held the right buttons on the maft pro, re-set the settings, then re-set her up, i adjusted my fuel pressure to 25vac 35 no vac. and i pulled the ecu efi fuse
i have tried to re-programe the analog out put's, but the soft wear doesn't have any conformation saying it's ben changed, i just can tell that the programe button doesn't become clickable after making a change.
i have the lc-1 reset to factory defaults, analog 2 reading wideband and simulated narrow band analog 1,
drjonez said:as the LC-1 instructions state, you have to orient the LED properly....
pimptrizkit said:... i have green wire to maft pro purple, white to blue, to ground, ...
americanjebus said:...
purple wire from maftpro is grounded w/ the white and blue wires from the LC-1, ^ i will find a seperate ground for the blue wire based on hecklers post though.
