hey guys i have a question, i just recieved my maft gen2 and i was driing and trying to tune a little to get rid of fuel cut and ecause my air fuels are at about 10.5 via my zeitronix. so i go out and i take about 5% out of around 4krpm and up, and it doesnt change much on my zeitronix. so i take some more and i see it start to make a change. when i actually start noticing a actual change of more then .2 AFR, i end up at about 20% from 4600 and up. i thinkin that that is way too much to be able to take out on a stock AFM stock injectors and stock fuel pump and not make a 1-2AFR change.
can the computer learn a fuel curve and correct in open loop? or am i doing something wrong. i seems that its hit and miss with the air fuels, ill make one run and itll be around mid 11's and ill be like sick, and without changing a thing make another run and its back to low 11's high 10's
i did notice though if i maybe 3/4 throttle it, itll run at around mid 12's but if i full it goes down to around 11 flat.
anyone got any input on this?
