ok i got my 3.5 inch maf, i set it to LS1 aluminum and it wasnt the right scaling and i found the closest match was on 3.5 inch LT1. i still had to play with the maf scale adjustment to get it to make the VF 3 volts but it was alot better then the 3 inch maf i had. i got her all tuned up and the only problem im having now is that idle tip in problem.
also my zeitronix wideband isnt displaying right threw the GEN2. its displaying 18:1 when its at 14:7 at idle. te voltage into the maft its 3 volts. i looked up the air fuel voltage scale on zeitronix;s website and 3 volts does equal 18:1 but its wierd that the gen2 is revieving a half volt more then the zeitronix should be putting out. im gona look into the wiring to see if i can figure it out.
any information on the off idle tip in? i tried adding about 10% at 400 on teh low tune and it helped a little bit but its still there.
Thanks,
Dan
Thanks,
Dan
