Maf Pro Install question
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Got it installed today. Started right up and held a perfect idle. Nice piece ofr the MKIII.
The only question I have right now is that off idle I get a stumble that I am thinking is a lean condition because the LC-1 bounces way lean before the r's come up.
Any help would be appreciated.
Also my TPS is sitting at .50 at idle and goes to 3.59 at WOT.
Haven't messed with the low, mid and high tunes as of yet.
Thanks
Wayne
bigaaron
4,692
Pomona, CA
www.driftmotion.com
3rdtimearound said:
Lo table +20% up to 3400
Mid table +10% up to 3400
hHi table +10% up to 3400
still stumbles off idle
That sounds like it is way too rich at low throttle. With 550cc injectors mine is almost all -xx% with the main scale at -15%.
SPD TRP
Apr 12, 2005
526
Katy Texas
Been messing with the response page, the TPS enrich I took up to 1.50, with no real change.
If I rev really slowly it will come up ok.
But if I crack the throttle abrubtly, the W/B goes off the scale lean, hard stumble, then r's come up.
I used the info that came with it to set up config and set up pages
"Quick Setup for Supra MK-III for translator pro 4.40"
SPD TRP
Apr 12, 2005
526
Katy Texas
tookwik4u89 said:
When i had 4.40, i had the exact same problem, response tuning did nothing, it is WAY better when i loaded updated software. I was lean off throttle and fat open throttle, i went -15 mainscale and fattened up low rpm tables. IT is different for everyone , keep that in mind!!, try that, 4.63 i have now i believe, also has timing control.
http://www.supramania.com/forums/showthread.php?t=6950&page=28
Thanks for sharing your experiences with the pro.
I need to get and load the new software. How do I load it, does it need to be in the car and on to accept the new software?
SPD TRP
Apr 12, 2005
526
Katy Texas
Keep getting error message when trying to update pro with new software.
Laptop says "update" is not a good command or something like this when I double click the .bat file to get it started. WTF
SPD TRP
Apr 12, 2005
526
Katy Texas
Well I get the laptop to say waiting for the pro, but when I power it on holding the left two buttons down, the range buttons, it never recognizes it.
Is this the problem you are having BA?
malloynx
NC
WOOOH... what are you guys doing..
i just installed 4.65 the other day, then removed it for the 4.20..
anyway..
what are oyu messing with the tps tip -in..
leave that shit alone..
with 550's you should be pulling fuel and not adding... what is your fuel pis at??
also to upgrade. you need to hold the 2 left buttons then give power to the PRO while still holding the buttons.. mine works like a charm>>>
SPD TRP
Apr 12, 2005
526
Katy Texas
Why would you do that?
anyway..
Check out the first post, going lean off idle. According to the manual, that is where you adjust.
I don't have 550's, don't know where you got that from
That's what I was trying to do, but the laptop never recognized, just said waiting for the pro.
