lsd differences....
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Too crappy a pic to tell from that.
G282 = 4.30:1 89+ N/A Non-LSD
G284 = 4.30:1 Pre-89 N/A Non-LSD
G285 = 4.30:1 N/A LSD
G305 = 3.73:1 89+ Turbo LSD
G315 = 3.91:1 Pre-89 Turbo LSD
A stock N/A with W58 and 4.30:1 rear end will be doing about 65MPH at 3000rpm in 5th gear.
SySt
Burnsville, Minnesota
I would just like to add my thoughts. There are differences between the LSDs. What about the 1JZ's with TorSens. I beleive the TorSen came in two ratios. 3.8ish and 4.1ish.
Also, so many people just think of a differential as either open or LSD. That is WAY too general a term "LSD". There are so many so-called "locking" differentials. Firstly your typical LSD does not "lock up" so stop saying they do. The majority of LSDs out there use friction discs and pressure against the side gears to limit the speed variation between the two outputs and further limit the torque difference. Not all "clutch-type" LSDs are built the same, you can vary disc pressure, the discs themselves. You can even have one-way discs. TorSen differentials use gearsets to create a bias curve which determines the torque split of the two outputs. Viscous LSDs use friction through a fluid to keep the speed variation of the outputs in check.
Sep 3, 2006
52
Mastic Beach
so these numbers would be in my vin?
i guess my speedometer is off then cuz it shows 60 at a lil over 3k....i guess that explains why it dont work anymoire hah....
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
All MK3 LSD's are clutch-pack, with the exception of the Torsen in the JZA70. Which came in 4.10:1 and 3.91:1 ratios depending on M/T or A/T.
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
in that pic it ends with 303W58 so i dunno what that would be..... turns out mine is is 315R154 so thats the 3.91, i must have just had bad info last time i checked.
drjonez
the motor city
www.4cefed.com
SySt said:
I would just like to add my thoughts. There are differences between the LSDs. What about the 1JZ's with TorSens. I beleive the TorSen came in two ratios. 3.8ish and 4.1ish...
http://www.mkiiitech.com/forums/viewtopic.php?t=40
Jeff Lange said:
Looking at it closer I can see what it is. It's a European MK2 Supra.
F303 = 7.5" 3.73:1 2-pinion clutch-pack LSD.
W57 = Tranny
agreed. the MA61 gives that away...
ValgeKotkas
2,224
Over the pond
Oh shit :) Then someone made the same joke on the Firewall and stuff... must be stolen from sumwhre sumtime then ... brr... I though sumtin was wrong on this MK3.. ;)
