Low oil pressure?
wdb
Vancouver, WA
I just bought an 86.5 supra and I was wondering if my oil pressure was too low. I have the stock oil pressure gauge and the other day the needle was just below the 2 mark at idle and when I would rev it a bit probably to about 3k rpms it would climb up to the 3 mark. This evening before I turned it off it was getting down to the 1 mark at idle.
Another thing, my gauge goes from 1 to 8. Does that mean 1 psi to 8 psi? What is the normal level? I'm actually pretty worried about it, it has fairly low miles and runs pretty good but has a slight lifter noise that seems to clear up after the engine warms up. Any help is really appreciated.
wdb
Vancouver, WA
Yeah, I also just looked at the gauge and the measurement is in kg/cm squared. So the stock gauges are that bad huh? Well then fu@k me runnin'! Any other thoughts?
I just checked the online owners manual and it says that it's supposed to be at .3 or higher kg/cm at idle so I guess it's fine. but when I rev it to 3000 rpm it's at about 2.2 kg/cm and it says 2.5 to 5 is normal. I guess I just started $hitting my pants when I saw that it was down to 1 last night and it seems to have been running worse than when I bought it. Noisier with more of a lifter noise too, maybe I'm just trippin though. I figured it would've been just my luck, I get a car that I really like and immediately it goes to hell.
Mk3runner
2,033
Nor Cal
the oil gauge is my only real bitch, mine responds quick, but when it comes to 7M and oil pressure I want to know now! the gauges tend to lag, my 92 is quick but not enough for me. older ones are sometimes worse.
I like warning if pressure is lost. *cant always eye the gauge lol*
also, remember to always overfill 1qt on oil change and maintain that. its a cheap but nice way to not starve out the motor.
mkIIIman089
Ohio
Which USA cars had kg/cm stock OP gauges?
I've never been a fan of that 1 qt overfill stuff, it's just a pathetic band-aid for people too inept to check their oil on a regular basis.
JDMMA70
2,550
Houston
i dont think any USA cars got kg/cm gauges, my stock one responds pretty quick once its running. Not as fast as aftermarket but it doesnt seem all that bad.
mkIIIman089
Ohio
So... where did this car's cluster come from? LOL
My stock oil pressure gauge is slow as molasses, and it might be accurate but it's so hard to tell because the scale is all over the map.
Mk3runner - You can post all the links you like, I'll never recommend it. ;)
Mk3runner
2,033
Nor Cal
to each his own lol.
Or for people that drive their cars hard enough to uncover the pickup under high G loads when it's at the stock fill level due to the totally useless pan/baffle design used in the 7M.... :nono:
Guess that makes me inept in some way, but hey I haven't lost an engine since I've been doing it.
JDMMA70
2,550
Houston
My guess would be Canada (would have a km/h speedo) or the Europe (UK has a mph speedo dunno if the oil pressure gauge is in kg/cm or not) or maybe it was a patch job (took the gauge from a Canadian cluster and put it in)?
And i run a 1qt over never hurts to have extra piece of mind.
DBN
FML
Jan 22, 2009
247
Fairfield, Ca
1 Quart over FTW. No use in seeing your motor die from something as stupid as "I cornered to hard and my engine went kaboom, wtf?".
wdb
Vancouver, WA
I know, what a strange deal but I live right in the good ol' US of mo friggin' A! Maybe my supra wasn't an original US car. So anyone have a stock oil gauge that isn't kg/cm? I'm sure that most aren't but I'm just curious.
