low end garbage!! 86.5 N.A.
bugz66
14
oakland
ok,well my low end and mid range torque sucks.trying go around the twistys with great suspension set up but no low end,around 2000 - 3500 rpms.
engine is stock NA 5 speed, intake, gutted cat, 2.5 exhaust.
3.73 lsd
255/35/18 tires/rims
tuned up and timing in spec.10-12 deg
all i have is high end,pulls hard!
any suggestions on what it could be?????
thanks
mecevans
1,295
M-bay, cali
Why do you have a turbo rear end? You need to get the engine into it power band just shift to a lower gear. When I cruz big sur I never drop below 3500 rpm.
bugz66
14
oakland
well its kinda hard to shift to first while going 30 - 45 mph.
im usually in second while going though some tight corners,but if rpms drop
no low end at all.
no low end at all.
Heel toe is your friend, plus your gear ratio isn't helping (there's a reason NA's came with the 4.30's)
bugz66
14
oakland
yea i was hoping it wasnt the 3.73 LSD but i think i will get a 4.30 LSD soon.
thanks for the advice and not hating(like some honda fools)
When i had the 3.91 in my old n/a car is was awesome to go through canyons staying between 3-4 and never bogging.
CT26smoker
223
Houston
How many NA can even pull 85% of max rpm with 3.7 or even 3.9 rear ends ?
Not many......
There are hp-mph conversions all over the net.
A wishful 200hp can not pull a car as big as a MkIII to 185 mph.
And learn to shift, or fix your syncros so that you can,
Then gear lower, and go faster.
xzeror
1,356
Miramar, FL
no idea, i just remember someone posted a chart showing rpms with diff differentials and transmissions. I verified i had the r154 with one of the turbo rear ends. Does anyone have that link or chart?
