Yes, Volvo redblock B230ft with the B234f 16v head swapped on. I pioneered alot of the things on the motor and most everything was a one off. It had a stroked forged crank for 2.5L, h beam rods and forged pistons. 2mm over valves, behive and titanium retainers, 272 cams, my own header and intake with a divided 6262 all through a T56 and Ford 8.8. I was able to fab on a DSM cas sensor and was running a complete 1g ecu and harness that I got from a 91 Eclpise. I then tuned it with ECMLink as a complete stand alone.
I had verted engine from the standard 20* tilt, had a crank scraper, custom alum pan with a crazy oil feed system right off the pump, out the pan to the oil filter/thermstat/cooler area. Car was really fun to drive and made enough tq at 2400rpm that I could cruise in 6th at 75mph and get just over 30mpg!
