Little help....again.
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
ok so my cluster light doesnt work at all. I just noticed it yesterday when i turned the headlights to see if they work properly and i noticed my cluster light doesn't work at all. Like, there is no light at all there. My climate control light goes away when i turn the lights on and the cluster is just plain dead.
Cluster does work. The cluster light doesnt work.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
did you check the dash dimmer? i know i've hit it on accident on occasion and wondered why it wasnt working :)
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
i don't even see dash dimmer anywhere and the dash is not even dimmed.. Its dark and there is no light at all. I know when you put the dash dimmer. you can still see the light on your dash. but my dash. no light what so ever at all. All dark and when i turn my headlights on, the climate control lights go away and when i turned them off the climate control lights come back on.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Nope. :)
theWeezL;1010799 said:
Nope again. :)
jetjock;1010802 said:
LOL!
1) The dimmer is on the left side of the steering wheel, either a) on a dial switch in the face of that panel, or b) on the underside of that panel.
However, suffice to say, this problem isn't likely to have anything to do with it. There is a 99.9% chance that you left your hazard switch (four way flashers) unplugged. Doing any dash work recently? :)
Take a look: http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=70
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
/\/\ ill check it out in a little bit.. ... no dash work... I bought the car and didn't really look at it at night.. my buddy drove it home at night and said it worked fine.... maybe something happen along the way... ill check out the hazard switch... where would it be unplugged ?? in the engine bay or inside the car ??
Kangae
Buzzin' Half Dozen
Sep 13, 2007
249
Utica, New York
I know this doesnt really help anything but I just wanted to mention how bad I think the placment of the under-dash dimmer switch is...every time I go to hit the clutch I dim it a little bit...
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
/\/\ that maybe be it why mine was dimmed out.. but my dimmer is blending in with a wried greyish dash thing the previous owner installed. im pretty sure it aint stock.. ill take pic and post it here
shaeff
11
Around
So what exactly was the problem? Dimmer or hazard switch?
