Kyle's World!
T-Roy
supra parts truck driver
Feb 24, 2006
Dublin,ca
profile.myspace.com
HellsLegion said:
Just gonna add this pic here for easy reference.
Its a picture of my girls.
I go to either of them for a good time yo
EWWWWWWWWWWWW
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
LOL @ this thread, might as well be moved to OT. ;) Congrats on what you've done so far, it's nice to see a build that's moving quicker than mine. New suspension should be put on my car sometime next week, I'm stoked. Also, this thread is confusing, are you still N/A?
BTW, brown interior FTW!
-Matt
chriso
Supranian
Bay Area, CA
JustAnotherVictim said:
Yeah, I bought that block and IC/piping from you. I still never used the block haha.
I had the red 88 with the solara rims at the time.
Oh yeah, long time ago. Now I remember. Sorry, got to keep Kyle's thread on topic.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
my progress just moved 5 steps back. I was on the twisties today out by Santa Cruz whwn suddenly. My brake pedal hits the floor. I almost shit myself.
We all pulled over (1 mk1 mr2 2 mk2 MR2's a spyder an alltrac celica and me) and we check it. Im pretty sure my master cylinder/booster thingy.
Im fine. The car is fine.. I drove almost 50 miles home with no brakes. Lots of downshifting.
Piss.
Ill get pics of my drive soon.
Oh. And thanks for the skeet skeet on my sandwitch last night Jenny =]
Big Wang Bandit
Feb 21, 2006
7,551
Here are some pics before everything got gehy!
Ignore my hood. Better airflow.... lol I just gotta realign it.
One of the guys, The dood with the Purple two, got pulled over for swerving to avoid some stupid jerk that ran out into the street and the cop pulled him over for not yeilding to a pedestrian. Jerk
Wheee There is also a red mk1 mr2 not in the pic... Its gorgeus.
Big Wang Bandit
Feb 21, 2006
7,551
It wasnt boiling... As far as I know. Wouldnt the top come off if it boiled? It is VERY worn tho. So tomrrow I am going to drain it, refill it and burp it. See if that helps. if not. Chris, ya got a brake cylinder assembly? :cool:
Big Wang Bandit
Feb 21, 2006
7,551
BTW I believe they gave out after a VERY hard stop coming up to a stop light in the middle of fucking nowhere for a one lane road. So its gonna sit all night. Then some DOT5 fluid is going in lol. Never gonna boil!
Big Wang Bandit
Feb 21, 2006
7,551
Probably what happened. Sorry for the not understaing of words lol.
But still none the less. It needs to be drained. Its brown. Nasty. Gotta read in the TSRM how to go about doing that.
Grab some vac hose put it on the furthest bleeder then crack it a touch and get a bud to push the pedal, repeat a few times for each wheel then buy some Metholated Spirits and run that through repeating the process until it comes out clean.
Now get your new Brake fluid and repeat until it comes out clean discard the contaminated fluid and bleed using fresh fluid.
Brake fluid by nature is "hygroscopic" meaning it attacts water so if you just drain and replace you might still have water contaminating the system by using the metholated spirts it's surrounds the water molecules and removes them giving you a clean system. (also works for water in the fuel tank)
Big Wang Bandit
Feb 21, 2006
7,551
So basically do this?
http://www.cygnusx1.net/supra/library/TSRM/br/BR_06.html
The best way to get rid of the fluid in the resivour is a sponge or syringe?
Then work the bleeder valves on the master cylinder.
Wash it out with these spirits... I figure any hardware store will have some... mineral spirits?
Flush that out.
Fill with new fluid.. bleed. Top off. done?
I figure ill need to bleed from the calipers as well?
Ignore what the TRSM is saying.
Bleed it from the bleeder nipples on each calliper you're trying to flush any and all crap out of the system , you want the Metho to be clean when it comes out before moving onto the next step.
By rights brake fluid should be changed each year or so but most times it's only ever changed when there is a problem like this or a leak....
Big Wang Bandit
Feb 21, 2006
7,551
Okay IJ. Ill give it a shot.
Im assuming I should add the Alcohol while the valves are open? Then procede to stomp the brake pedal till it emptys itself? Tommrow it shall be done
