JZA70 vs MA70 motor mounts
May 18, 2007
704
Aarhus
What are the differences between the stock JZA70 and the MA70 motor mounts?
They have different part numbers:
JZA70 : 12361-46040 http://www.toyodiy.com/parts/p_J_1993_TOYOTA_SUPRA_JZA70-BJPVZ_1107.6.html?hl=12311
MA70 : 12361-42050 http://www.toyodiy.com/parts/p_E_1992_TOYOTA_SUPRA_MA70L-BJPVZC_1107.2.html?hl=12311
I have swapped in a 2JZ-GTE with automatic transmission (the JZA80 one) using the MA70 mounts. And to position the gearbox correctly in height I needed some spacers. But when putting the spacers on the rear housing of the gearbox I find that the engine oilpan hits the nut holding the steering rack.
So I was wondering if the JZA70 mounts are slightly higher than the MA70.
Has anyone compared the two?
May 18, 2007
704
Aarhus
Can you use the mkIV mounts? I have some but it seems like they have a wrong angle (a different angle compared to the stock MA70 mounts) and they also had a locating stud in the wrong place.
Mk4 mounts can be used in the mk3 no problem. Just have to grind off the little stud.
May 18, 2007
704
Aarhus
Ok. I just thought they had a difference angle between top and bottom.
The ones I have look like this:
I haven't checked but are they of the same height as the stock MKIII mounts?
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
kneedragger85;1696655 said:
I couldn't notice any vibration with the MKIV TT at 400rwhp.
cool i think im going to get some soon down the road..i have 7m also and should be close to 400hp pretty soon..
kneedragger85
363
Boulder, CO
The MKIV TT mounts I have look like this,
94122d1163600039-finally-the-moment-i-have-been-waiting-for-7months-for-trd-motor-mounts-motor-mounts.jpg
May 18, 2007
704
Aarhus
Hmm, why are they different? What year are yours? Mine are from a 1993.
---------- Post added at 01:36 PM ---------- Previous post was at 01:35 PM ----------
Seems like the brackets on the mkIV subframe must be different between your and my donor car. My mounts have a slight angle.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
The brackets you have are the wrong ones, You have to use the JZA70 brackets, It seems you have the MKIV/soares brackets...
kneedragger85
363
Boulder, CO
I believe I purchased 1998 TT mounts way back in 2007. The photo isn't mine but shows the same mounts I have...not brackets. I purchased BIC brackets and already completed my swap.
