JZA70 springs on MA70 question
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
First off, I did read the couple threads on this same topic, but I have some different questions that werent covered. I dont have enough money for a full spring/strut combo so I'm just getting the stock JZA70 springs for now.
1. Has anyone had experience using these on the stock pre89 struts?
2. Will there really be an ugly/weird difference in ride height when comparing front to back?
KeithH
Portland, OR
Are your current springs broken? If not... save your money. Get a new set of springs for about $200 - we won't even talk about the labor to install stock springs with stock springs (even if you do the work yourself).
Do it once. Do it right!
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
Mine struts probably are shot, but I dont have enough for a whole new setup. My car ride now doesnt ever bottom out or anything. I just want the JZA70's because they only lower it a little bit and are still good quality.
Borhor, so you think that if I put just the springs in, the ride height will still be even all around?
logan
3 laws safe
Oct 4, 2005
109
U.S-U.K
Are all the jap springs lower ? They had so many different models , like the 2.0- the 1j - the 7m- the turbo a , how do you know whats what when buying springs ?
tsuper92
supra addict
Apr 7, 2005
1,376
mass
jza70 spring's are alot lower then are tems suspension.probably a good 1.5".
you put the lower spring's in and then you probably won't be able to align your car.frozen cam bolt's FTL
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
sorry i don't know i did do a post in GD at one point with spring rates for MA70 and a whole bunch of after market ones.
suprastanger507mgte I sold the TTR springs with the Bilstien Shocks together. I almost wish i kept them. I have H&R's on my car at the moment
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
so.....to answer the first question....has anyone had just the jza70 springs on ma70 struts? i cant afford the whole spring/strut setup right now. and i also dont mind pulling it all apart just for a spring replacement.
johnathan1
Supra =
Aug 19, 2005
5,056
I repaced my stock setup with JZA70 Springs (not TT-R), and KYB GR-2's...they are great shocks and are really cheap...IIRC, you can get a full set for like $100-120.
And yes, the JZA70 Springs lower the car about 1.5"...Here are a couple pics:
I like them, I think they give you the perfect ride height...the others are too low, even with these springs, I still scrape on driveways and speedbumps occasionaly.
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
Nice, I really like that height. I'll look around now, but is that the usual going rate anywhere for those struts?
I just bought some aerosol aircraft paint remover so come spring my wheels should look like yours.
