Ive been told that the stock front sway bar in a JZA70 is stiffer then one in a MA70. They both look pretty similar in appearance and measure the same outside diameter. Would like to swap them out if theres actually a difference.
I know of white line sway bars but Im just curious about the factory bars. I have a jza70 sway bar from a parts car and want to know if it is worth swapping in over the ma70 sway bar.
Im running k-sport coil overs, not sure on the spring rates though. They are a softer riding coilover compared to other brands. Think it would ride like a bucket of crap with the TTR sway in it ?
with stiffer springs, you need less sway bar to keep the same roll stiffness. So it's not as much the speed of the weight transfer, it's the stiffness of the car and balancing it out. bigger sway bars on an already stiff suspension can decrease the total grip capacity of the axle due to additional lateral load transfer from the sway bar. generally a stiffer sway bar will transfer more weight from the inside wheel to the outside wheel under cornering.
