just throwin this out there
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
americanjebus, what answer did you turn in? And let us know whether you get it right or wrong. :) I'm betting I'm right.
Let's hit this from a different angle.
Do you think that you can have acceleration when you are already at 100mph? SO for instance, if you accelerate from 0 to 200 mph, do you think that you are accelerating when you hit 100mph?
The only difference is the start and stop speeds... and as acceleration is a change in velocity, the start and stop speeds are irrelevant.
In other words, the only time that your acceleration is zero, is when your velocity is constant. If you are changing speeds, whether it's from 0 to 200, -100 to 100, or 0 to -200, your are always under acceleration.
L
lanky189
Guest
alot of people get confused with the false concept (when dealing with conceptual physics) of de-celeration. There really is no such thing. Acceleration just what grim says..a CHANG in velocity.. velocity is speed and direction..so change direction and guess what..you've changed acceleration. Slow down..and your accelerating...speed up and your accelerating..its all the same thing..
turbo
Mr. Clean
Apr 27, 2005
135
Calgary
The coordinate system you choose sets up the sign of acceleration and direction of the velocity relative to the displacement. The answer is yes because the acceleration is still changing even though the velocity is zero. A ball in the air can have zero velocity but a negative acceleration.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Ball in the air - damn fine analogy. Thanks for the idea!
OK... here we go.
Gravity accelerates EVERYTHING on the planet that isn't on the ground at a specific rate, 9.8m/s^2 - and it does this all the time.
So... throw a ball straight up. When it hits the top of it's path, it's velocity = zero. However, it's still accelerating, as gravity is a constant, thus, it will fall back to earth.
SupraMario
I think it was the google
The Farm
Well, i have come to the conclusion that i was wrong, i had something else in mind and after re-reading grims post i know understand the concept.
Grim-1 / Me-0
americanjebus
Mr. Evergreen
wa.
OK... here we go.
yea too bad i got that answer to late. i wrote no, but the afternoon after turning it in i realized. OH shit i can happen cus i had never thought of an expample, then ithought of the ball.
my teacher used the same exampl. constant accel of 9.8m/s acting on all objects at all times but when the ball stalls the velocity is zero but teh accell will ALWAYs be 9.8m/s due to gravity.
i wrote no so i got it wrong but atleast i know the real answer now. meh 9.5/10 isnt a bad score i geuss.
Tigerkat229
Sexy Kitty
Aug 2, 2005
Dallas, TX
www.xanga.com
OK... here we go.
Shit...
All those physics classes and i still fuck this up...
Ok i was wrong, way to go Grim :)
americanjebus
Mr. Evergreen
wa.
what do you mean.
the 9.8m/s is the acceleration due to gravity, every second after you drop something its rate of fall increases by 9.8 meters every second. the 9.8 IS the acceleration but only in terms of gravitational acceleration
its wrong to call it gravity, cus gravity itself is something else.
Squid699
Manic Mechanic
Chesapeake, VA
The sea-level gravitational acceleration is 9.780 m/s², not just 9.8m/s. This is constant accelleration until the object reaches terminal velocity, where atmospheric drag cancels out further accelleration and then falls at a constant speed.
L
lanky189
Guest
Terminal Velocity, also a quasi-enjoyable film staring Charlie Sheen
Shawndude
Van BC
It's all relative.
As Grim points out, acceleration references itself, not some outside measurement or reference. Just because you're standing still relative to something that usually doesn't move, doesn't mean you're not accelerating.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
we are all technically accelerating, even when standing still. the earth is moving, hence our bodies are in motion relative to a point in space.
L
lanky189
Guest
Shawndude said:
It's all relative.
So you're not dead eh? :wavey:
what the hell is goin on shawn..havent heard from you in a long time.
