Just bought a 88 supra turbo have a couple questions
rolohaun
Edmonton
Hey Everyone,
I just bought a 88 supra turbo and I have been trying to get it running. It turns over just fine but won't fire. I just had some questions from what I have read about other people having starting issues. Things I am going to check :
- Trouble codes ( Can this be done if the motor will not run? With the key on th on position with it give me codes? )
- Fuel ( Whats the best why to check if I'm getting fuel? )
- Fuel Pump ( Not clear on which terminals I have to jump to test this )
- Spark
Car ran in april supposedly and everything looks in order, this is my first supra and I am still new to them. I have searched but found little help about checking if I am getting fuel and such.
Thanks
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Hi and welcome!
Here is the link to the TSRM. The lifeline of all MKIII owners!
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/default.aspx
Codes: Yes, the car will give you codes with the key on the 'ON' position and the jumper installed properly. Refer to the above link for jumper location and instructions.
Fuel: You can check to make sure the fuel pump is working by installing a jumper with the key in the "ON" position. Again refer to link above.
If the car sputters and sounds like it's trying to start, pop the hood and shake/rattle/move the CPS and associated wires. You may simply have a bad CPS wire!
Good luck and post findings!
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
spaying starting fluid directly into the throttle body while cranking is a good way to see if its NOT getting fuel.
rolohaun
Edmonton
UPDATE
I checked the codes and there are none, checked the fuel pump and the jumper wire sparked and got warm so power there. I sprayed some starting fluid in the throttle body and the car started for half a second so it's no getting fuel. When I got the car the tank was empty so I put 16 liters in it about 3 gal is this enough? should I put a little more in to prime the system??
Thanks!
rolohaun
Edmonton
I will check the timming but I don't think thats it, it seems to want to start. I will put new spark plugs in it too as I have no clue how old they are. Maybe a new fuel filter.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
turn the ignition to on, and jumper +B and Fp. If you hear the fuel pump and can hear fuel passing through the return line, the pump isn't your problem.
