Anyone know if it even makes a difference? I can't see any kind of indication that one side or the other should be up...
The rings are designed that way so that the gases and pressures of the combustion actually go behind the ring and push it out against the cylinder wall creating a "seal" between the piston and the wall. This causes a more efficient power stroke of the engine.IJ. said:Usually marks go Up Dave!
From JE>>
• Always install Pro Seal rings with indicator marks facing up
(Sportsman rings without indicator should be installed as
shown in fig. 3)
