jdmfreak's A NEW BEGINNING (BUILD THREAD)
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Over the last week I got just about everything put back together still have my dash apart but once my coil boots arrive I should be able to fire her up :) well as long as IJ didn't jinx me that is ;-)
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
IJ was right :p I had forgotten to connect the efi main relay to the circuit opening relay so my fuel pump had no power..... Now to borrow a timing light and get her started
Been doing this shit 37+ years and still miss things, anyone that says they don't is a liar ;)
supranewbie
377
46°47.0'N 120°09.0'W
Unless you've already found one, I can drop off a timing light after work tomorrow.
nathaninwa
377
Aberdeen, WA
Sparky33;1985241 said:
youre using ls1 coils right? what boots are you using?
BryanDyer;1985251 said:
LS2 truck coils, not sure about the boots I'd like to know too since I'll have the same.
CP059 from duralast or omnispark. I found mine at Orielys. If you have spring issues like I did, MOJO Performance has some kickass springs Im running now.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Well attempted to set timing last night but was getting way too much noise from the cas...... Sync loss after sync loss 11 then 17, 11then 17 won't even spark enough to set timing :-\ I am going to add some resistors tonight and see if that quiets it down enough
