jdmfreak's A NEW BEGINNING (BUILD THREAD)
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Debating clipping up my stock harness to use pigtails for respective plugs (coolant temp, Iac, c1....) is there a cheap place to get stock plugs for such things I would rather have a perfect harness
Edit: maybe that guy on here who makes harnesses would know where to get them
Sent from my C811 4G using Tapatalk
Pyro15D
kind of a lucky dude
Aug 24, 2008
647
4
Whidbey Island, Washington
Digikey has worked for me, but you have to know part numbers and such. If you aren't pretentious about your connectors, find other Japanese vehicles at your nearby junkyard. Many of the connectors are the same as on other cars.
Signature changed to make Bird happy.
Pyro15D
Aug 24, 2008
647
4
Pyro15D;1979245 said:
Digikey has worked for me, but you have to know part numbers and such. If you aren't pretentious about your connectors being brand new, find other Japanese vehicles at your nearby junkyard. Many of the connectors are the same as on other cars.
Another thing, Tweak'd performance sells the connectors and such as well.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
OK thanks that was the guy I was thinking of I'll look into tweak'd see his prices if not ill just clip one of the 3 harnesses I have here
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Yay wires
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
well since i havent updated with purchases in a while
thanks to Aaron@driftmotion, i got a ss braided power steering line and na-t turbo oil lines for my t series turbo
thanks to ebay, ls2 coils and clips,
And big thanks to Wardog for ffim,and eagle rods
all on their way or will be shortly:)
Pyro15D
Aug 24, 2008
647
4
Those coils you got are some of the best you could get. They have the external heatsink. I believe you need to set your dwell to 4.0ms. If you go too high, the coil will automatically spark, which means you would have a dangerous over advanced spark.
If you go too high the Coil will overheat split it's case and spew Epoxy and goo everywhere....
There are very specific requirements for dwell, 4ms across the board isn't it...
Do you have a table for voltage/rpm?
Pyro15D
Aug 24, 2008
647
4
Sorry IJ, i should have been more specific. 4ms is max dwell. Tunerstudio calculates the table based on the max dwell it can run vs rpm. I never got into voltage compensation for mine, but I wasn't really trying to squeeze a lot out of the motor. As far as where I got my info about the coils firing early with too much dwell, that came straight from the manual. Lemme find the link and paste it here...
http://www.msextra.com/doc/general/sparkout.html
It is in the middle of the page. If this info is wrong, I apologize. I don't like to spout crap info.
nathaninwa
377
Aberdeen, WA
As of current, MS cannot do varied dwell time based on load or rpm. I have asked for that feature, but have not heard anything (but as said, it has voltage compensation). Im running 3.7ms and just took out another set of plugs in 1000 miles. Ive been running a .030 gap, and talking to my MS goto guy says I need to actually open the gap up to about .035. That the coil is so powerful a smaller gap actually acts like shorting the coil out. He runs a .040 gap on a 900whp car.
Im going to try iridiums this time tho, one heat range lower at an 8, over the copper 7's I have been running.
Guys on SupraForums were charging the coils to 5ms, but a lot of people were getting the coil break down and advancing there timing and taking motors out. IIRC, its been tested to 4.2ms
JDMFreak, do you want to sell 2 of them coils? Im putting together a 22re and have 2 left over from my set, just need to more. Im doing MS2 on that one.
