jdm ecu on a non jdm motor
VooDoo
Draggin ass on his build
Mar 20, 2008
342
Valdosta ,Ga
Is this possible? I have an 88 turbo auto. Can I put a jdm ecu on there if the years match or are they a different plug?
VooDoo
Mar 20, 2008
342
Valdosta ,Ga
That is what i am wanting to do is bin it. I know there are alot of controversy over it. It can be tuned without it with an aem but I am not sure it can with the maftpro. SO i am looking to get the jdm ecu. I have an auto so an ems would involve getting a trans controller as well. This will be a upgrade later on.
grimreaper
2,180
Dallas
a jdm auto ecu matching your pin out (gray or yellow) depending on year. Good luck man they arent a dime a dozen. no egr is about the only reason for this as it adds a speed limit (112mph iirc) as well. That can be bypassed by cutting the pink wire (before the timer runs out and the car explodes...;) ).
maftpro can easily tune for this with ptt. Dig through some more threads, its there.
May 18, 2007
704
Aarhus
I have a JDM ECU and it does have a speed limiter. Ask me how I know....
The JDM ECU has a purple sticker on it.
Why does it make the car run rich if EGR is still hooked up?
shaeff
Kurt is FTMFW x2!!!!
11
Around
Well, get the P/N so we can confirm it's actually a JDM ECU. ;)
shaeff
11
Around
I've got a list of P/N's at home, I'll check when I get there. :)
SupraMan1987
258
Hickory area, NC
The EGR is adding inert gas (exhaust) The USDM ecu is tuned for t and as a result adds less fuel during the EGR range. However, the JDM ECU is not and it adds more fuel. More fuel with less air means richer.
