jdm 7mgte to U.S. specs
j3pz
still learning
i started searching for it but got lazy, so here i am. what do i need to do to a jdm 90 7mgte if im gonna put it in a 87? what parts/sensors/connectors do i need to swap out? so far i got egr, tb, oil pressure sensor. i have parts from the old 87 7mgte to swap on. thanks in advance
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
also... random coolant hoses will be needed (the coolant hoses on the back of the motor going to teh heater core are routed differently, and make sure you have pics or something to look at for the vacuum lines under the intake mani... no fun
Erkenz
125
Michigan
And here I thought I could just go ahead and drop it one in my 88...
This is not good. Does anyone know everything you need to swap?
j3pz said:
um just outa curiosity whats the differences in tb? does the jspec not have hoses come out of it?
The linkage is different...right hand drive on the Jspec :naughty:
HellsLegion said:
Doesn't the ECU need to be swapped as well?
Jspec ECU will work fine...it doesn't have the EGR programmed in either. If you have the EGR removed...I'm thinking that is a good thing. You do have to have the correct harness for your year group...pre-'89 or '89+
j3pz said:
checked out that site and didnt really say anything i didnt know. but ill ask q's later
Since you seem to know all this...I guess we all can be lazy too :3d_frown:
j3pz
still learning
im sorry if i knew all this i would try to find a better way to waste more of your time than this, but i guess this is good enough... i only said that site didnt tell me anything i didnt already know, meaning it didnt tell me what i wanted to know. im asking what needs to be swapped out or replaced and why, if thats too hard for you than please dont answer, if this upsets you please say so and i will apollogize.
shaeff
Kurt is FTMFW x2!!!!
11
Around
nicely said, j-dub. i wouldn't have deleted it. but hey, only mods can see it now.
open wide, this is a big spoon:
you'll need the engine harness and ECU from an 87-88 car. they have yellow plugs/connectors. you'll have to splice a few (4 at most) 1-wire connectors from a late (89+) style harness onto the 87-88 harness because there are a few connectors that are different. it's very easy to do.
you'll need to find an HAC sensor as well, because the 87-88 ECU uses an EXTERNAL HAC (high altitude compensation) sensor. it's a three pin sensor that mounts under the glove box area. you'll see the wires for it on the engine harness.
unless you NEED the EGR to pass emissions in your area, then you can leave that off. in order to retain stock-style linkage, you'll need the TB as you already mentioned, and you're on the right track with the oil pressure sending unit as well.
the j-spec ECU will NOT work if it's an 89+ ECU and going into a pre '89 chassis. it would plug into an 89+ ENGINE harness, but then the engine harness would NOT plug into the chassis of the car, as all the connectors changed, so in short, you cannot use the JDM ecu if it's an '89+ ECU.
-shaeff
Thanks Shaeff...I thought it was best because I got to thinking it would not do much good really. I don't know everything about these cars by any stretch of the imagination, but I do read (a lot) before I will even ask a question. The way this thread developed just kinda got to me I guess. Thanks again man...you and the other mods do great work ;)
j3pz
still learning
thank you for the straight answer, and just fyi, i did try and look up on it many places (other forum, search engines, tech sites) , so i just gave up after i couldnt find what i was looking for. im sorry for lashing out but i dont like bein bashed or made to look like an asshole. i only thought you guys would be kind (which for the most part you were) and maybe answer my question, and id be on my way; now that this is done, ill be on my way. oh and im sorry for whatever intrusion i made by not bein able to find the info on my own.
j3pz
still learning
upon reading the thread about how to talk to the oldschool fellas i see i may have underminded you guys and apologize. i was being lazy to your standards and also apologize for that. i also apologize for being rude too everyone i was rude to... i only felt i was being picked on but i now see i wasnt. im sure this post wont have another flicker in any of your minds but id just feel better knowing id apoloagize. i am greatful for the help. i have been reading up on the other threads and older threads trying to understand why it is i need to swap the oil pressure sender, egr, temp sensor. thanks again for the help and again im sorry for underminding you, being lazy, and being rude
