Is my valve clearecne good?
Supra-K
233
Victorville CA
hey everyone, checked my valve clearence tell me if I need adjusting cause Im pretty new to valve work, could use youre help aarron and dave:icon_bigg
the measurements are in inches
Supra-K
233
Victorville CA
o and i know that the ex. side is suppose to be .010 and the ink. side is suppose to be .008 oo and I have NA cams in my 7mgte if you were wondering
Supra-K
233
Victorville CA
ok haynes says .008 intake and .010 for exhast, the trsm says .015-.020 intake and .020-.030 for exhast, so Im a little lost, but whatever Ill just go with trsm anyone know where i can get some shims for cheap?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Now it gets complicated.
You need to pull all the shims that aren't in spec, keeping track of where they came from. Then measure them with a micrometer and calculate what thickness you actually needed in each spot.
Then check to see if you can swap shims around to get most of them in spec.
Then either get your remaining shims ground down to fit at a local machine shop, or buy new ones if they need to be thicker.
Best place to get these for cheap is your local Yamaha dealer, same shims as they used in a motorcycle engine back in the day... damnifiremember what motorcycle engine, though. Some searching might turn that little tidbit up.
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
Go back and read it (tsrm) again, you're getting numbers confused. It also tells you on the bottom of the hood.
It's .15-.20mm and .20-.30mm, not inches.
Supra-K
233
Victorville CA
ok so for the most part I need to do some reshiming a majority of them is off Ill see what I need then hit up the fourm for the shims
that's in the TSRM as well, but it's nearly impossible to read on the online version...
it's not quite as easy to use either LOL
