ok, so the other day when i got into boost i noticed what sounded like a very quick smacking and sounded like it was coming from the rear turbo, the car pulled just fine and reached 14psi without any problems with the AFRs all in check. the noise only happens as soon as i go into the +. today after a cold night and not driving it for about a day i started it up i checked the dipstick and it was slightly milky, i checked under the oil cap and it too was slightly milky . i drove home and checked it again and there was no signs milkyness, the car runs fine apart from a tab bit of smoke a bit afterstart up and doesnt over heat.the car is parked now and
im going to perforrm a compression check tomorrow to see if the headgasket is toast but my question is, is it possible for coolant to leak through one of the turbos into the oil supply? and now that coolant maybe in the oil, is the head and block toast? lemme know what u guys think it may be thanks.
sorry for the paragraph.
