Is anyone using this battery? *batt experts input appreciated*
8,900
Cold cranking amps is a rating at zero degrees farenheight. Cranking amps is the rating at 32 degrees. When is it zero in Florida? Those are things you can consider.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Jake, Grim Jack said it best. Go this way and you'd better keep the motor and cold start system in perfect tune. Also keep in mind CPS signal output is proportional to cranking speed and there's a minimum needed. Add to that the ECU itself doesn't like a B+ below 11 volts. Imo you're asking for trouble.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
We use the 680 in our Formula cars which use a 3.5L Renault. I would recommend bigger. Car will start once on its own then you need a jumper unless it was just running and being charged by the alternator then you might get a few tries, but probably half the electronics running off of it. Go with the bigger!
Just my 2 cents,
Seth
mkIIIman089
Ohio
^ It's funny, with the PFM's we ran it was the same situation. If the dash was left on then you had even less chance it would start even once.
But in my Supra, after sitting over night in -10F it struggled a tiny bit that morning but it was never a concern of mine for it not to start.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
I have the PC680 and I love it. Bought it when I was NA, blew the engine, the battery died from cranking the car and using windows/other accessories. The battery sat for many months and I thought was completely dead, but I brought it into a batteries+ store and they brought it back to life. It sat in my garage for about 2 months and I just recently put it back in the car and it started up first try. The battery weighs 15 lbs. As already stated I also would not recommend this battery for people with large stereos or lots of added accessories.
becauseican
Vancouver
www.bicperformance.com
Have you guys thought of using a battery out of a late 90's Honda?, they are about 2/3s the size of the stock battery, and shoould still have a decent amount of CCA. you might even be able to turn it sideways to allow room for the IC pipe.
MRSUPRA
838
Maryland
Like I've said before, I have been using the PC680 for a couple of years now with no problems. It has a little trouble keeping a charge for extended periods of time when its very cold, but I'm going to invest in one of those $15 trickle chargers for the winter. Nothing like losing 25 pounds off the front end.
Boosted Supra
AEM 7MGTE 6765
Apr 7, 2005
353
Valley Stream, New York, United States
drjonez said:
you mean like this one?
why did i opt for the 925? simple: capacity. sure the 680 might cut it....but leave your stereo on for a few minutes or have some sort of drain and it's done. not to mention the problems you'll have if you ever decide to drive your car in the cold. i have several friends that run the 925 year round here in MI....
be aware that most of the "other" batteries you find out there are merely repackaged odysseys.
Doc, what's the height on that battery? And how much does it cost and where to buy? Thanks
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
If one of these fit up I'm deff getting one as well, I don't want to relocate my battery, because the local track require a on/off button on the back of you car for it. And damn my ABS wil put that battery option out of my avaliablitlity.
