Intercooler Install.. Hood Latch Support Bracket
YouGotSpooled
290
Saskatoon, Sk. Canada
Hey guys and gals,
Im in the process of installing my driftmotion intercooler kit. I was looking around and a few people actually REMOVE the hood latch support bracket which will also weaken the hood latch (not my idea of fun at high speeds). What is everyones thoughts on this? I was thinking of cutting off the piece that angles down (and gets in the way) and bolts at the bottom of the rad. I dont want to mount the intercooler at an angle.
Thoughts, ideas and suggestions welcome!
reeds420
76
Phoenix
Not sure about removing the radiator support bracket. When I did mine, that whole "angled piece" that hooks up to the hood latch came completely out. Gives you plenty of room. Also gonna have to relocate the horns, coolant reservoir, and oil cooler as well if you didn't know
How tall is it?
I fit mine straight no cutting. 31/12/3.
Also have have seen people just cut a notch out of the hood latch support.
Never seen anyone cut the rad support for an ic unless it was v mount.
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
I took an angle grinder to my latch support and supported the ic with it aswell
Its not pretty but it gets the job done
91whitepack
71
slidell, louisiana
I relocated my oil cooler, rad. reservoir, horns, and removed the hood latch support. I also made room by removing my a/c condenser because i dont have a functioning a/c anyway. im going to use what i have left of the bracket from the intercooler kit to support the hood latch. i cut up the bracket and used it to mount my intercooler straight up and down. its very stable and was easy to do. bumper cutout is just temporary until i can get the mvp air dam. here are some pics of mine so far.
MNBmk3T
217
Burnaby, BC
I have the exact kit in my car. Unfortunately the shop where I got my 1JZ swapped in cut the crash bumper to make it fit.
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
Supra_dan;1844830 said:
Suprasick, is that the new kit or the old one?
Not sure, I bought it off a guy about a year ago... Its the cxracing setup with the feed pipe running into a L shaped connector underneath the ic.
88SupraT
Boosting Supra
Apr 4, 2005
135
North Vancouver, B.C.
I picked the dm kit last year and ended up notching the hood latch bracket like suprasick, not that bad to do. Didn't even have to relocate anything aside from the coolant overflow when I did it.
Captain
80
NM
YouGotSpooled;1844854 said:
So you removed it all together? More pictures would be appreciated!
Better side pic:
This is the bracket the HKS intercooler and hardpipe kit comes with that I more or less copied:
Both brackets hold the hood latch as good as the OEM bracket did.
I'm running a 12x24x4, i basically cut the most of the lower portion of the latch support right off. Using the the top piece which anchors to the rad support/latch tabs and the nose panel beam, its plenty stiff. Easiest way to do it that i found. i had to drill out 2 spot welds for a tab that was attached to it so it could be removed. took a few minutes to do, plenty of room for intercooler as well
