I'm giving up hope of having the new 7M built and installed before the snow flies.
As it sits, it's knocking. Pretty sure that it's the rod on #5, though it might be #4.
So here's my idea. Slap in new rod bearings so that I can maybe get some seat time in, and get the car around to a few places for some suspension work without completely trashing the motor that's in there. Before the snow hits, I have to have the car snugged away for the winter, and there are things that I'd like done before then. Unfortunately, with my bearings just being shipped this week, I doubt that I'll have even a long block ready before then.
My plan would be to unbolt motor mounts, disconnect downpipe and IC pipe from the turbo, maybe fuel lines too if they look like they'd need to stretch. Lift the motor a dozen cm or so and drop the oil pan. I'll hope to not have to disconnect AC or power steering.
With the pan off, I'd hope to be able to replace the rod bearings. New FIPG for the oil pan, bolt everything back together, and be able to drive the car until the new motor is ready.
Has anyone pulled the oil pan with the motor in the car? I'm hoping that I can get enough clearance without dropping the transmission, though I don't mind disconnecting stuff.
