I'm repairing a BHG. Do I need to retourque the head studs and when?
grimreaper
2,180
Dallas
IJ.;1115953 said:
I've used Castrol LMM in the past with acceptable results
(I also use it as assembly lube as it's dirt cheap compared to tiny tubes)
ky dosent have shit on assembly lube... although if they could only make some that has a "warm tingling sensation"
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
I was thinking of checking what my cars HG was torqued too. My head gasket was replaced by toyota during the last owners ownership (2004/2005). I was thinking of checking the torque value but was wondering what I should put it too (I hope they knew that they had to be tightened more than the TSRM says but have no idea if they did that). I believe it has a toyota HG and Toyota hardware. I was thinking 72-80 ft-lbs, does that sound about right?
Yblegal91t
it finally runs!
Apr 22, 2006
331
C1 outer
so your saying you need to remove coil packs, i/c pipe, etc. 5 times to continuously re-torque the head bolts. Somehow I think I got confused and I've been reading.
jdub
Feb 10, 2006
10,730
Valley of the Sun
No...the 5 torque/loosening cycles applies to a new install. Not new hardware, but when the head is mated to the HG/block.
A re-torque is done after the engine has run...I wait for at least complete 5 heat-up/cool-down cycles. To re-torque all you do is just "crack" the bolts or stud nut counter clockwise, then torque back down a couple ft/lbs (5 max) more than what you used the 1st time.
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
jdub;1116885 said:
70-75 ft/lbs...it's a crap shoot once the HG has been on for that long.
Ok that sounds good. I may or may not even do it. I just have heard that people have had there head bolts become so loose after time that they can turn them by hand (if not torqued to the right spec) and I want to double check the torque and try to prevent that.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yep...seen that myself. If that's the case, it's usually too late to prevent a BHG.
buckshotglass
I love all your sounds.
This was my next question.:)
I just spoke to Jay, so I think I know the answer, but to clarify, I will be cracking them one at a time, and going to final torque before moving on to the next? It can't be a good idea to loosen them all at once, even just a little, at this point.
And would you use the removal or the install sequence from the tsrm?
Nate:
My experience with retorquing ARP studs with an MHG was the same as yours. I have a 2.2 mm Cometic, and used the ARP lube, went up to 85 pound-feet in small increments. Checked about 100 miles later (3-5 heat cycles) starting on the exhaust side, and found nothing looser that at assembly time. Head and block surfaces were propery prepared.
Yet most others in Supramania and Supras@Supras.com (working again) have apparently found a torque reduction. Did you try breaking loose at least one of the nuts, noting the torque wrench arm position, and going back up to 85 to see if the torque wrench arm was further clockwise? I think I did that, but now almost two years ago, I don't quite recall.
Looking forward to your reply. Thanks.
BernieK
BernieK@technicaldevelop.com
'91T, non-targa, refreshed JDM, Walbro, Lex, 550cc ND injectors, 57 trim turbo at 17 PSI (at 3000 pipe), '98 wheels and engine mounts (strong!), Lipp, modified stock FPR, Treadstone IC, hardpipes, Cometic, ARP, Random Tech 3" single cat downpipe, HKS LET-16 exhaust, Exedy organic clutch (street use), Raptor BOV (recirculated), deflashed valve bowls, exhaust helicoils, tower strut.
kwnate;1114528 said:
Checked mine after 500 miles. Click, Click, Click, Click................ I guess it was good piece of mind :dunno:
jdub
Feb 10, 2006
10,730
Valley of the Sun
Bernie - The required retorques I've seen are about 50/50 with studs....almost 100% with bolts. Of the ones where pre-load was set using the tighten/loosening cycles ARP recommends, zero actually required a retorque...did it anyway because there is no downside to doing it.
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
just to be sure, when using used arp bolts, used only once, still do a re-tourque after 5 heat cycles? any additional information for driving the car? i think i heard no boost for the 1rst 500miles or something like that?
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Yes, retorque after 5 heat cycles with both bolts and studs. Even once used ones.
It is best NOT to boost it during the those five heat cycles. Not really a matter of mileage.
After the retorque, pedal to the metal! ;)
