If yur making BIG F'n power, please look, I have ???s
JBatt87T
102
Athens, GA
Jake I would say go with something like an AEM EMS piggybacks are too riskey with that kinda power.
I still need to get down there and see that monster sometime man.
Jake
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Jake, how are those tires workin out for ya? :D
Im definately going to research the various stand alones... I would like simplicity... Ive heard tuning nightmares about the AEM... They offer classes on how to use the thing... Man... Im going to look into the Maft Pro, for one reason, if I understand correctly, it can auto tune... Thats the simplicity Im looking for... :D
rakkasan
Currahee!!
Fort Campbell, KY
Reign_Maker said:
Grant, I believe the maft pro will have timing control, if its not now its coming...
From what I've read, Dr Jonez is working on monitoring the timing & possibly controlling it later. You should read his "MAFT Pro is working" thread, lots of good info.
chevyeater
wastegate hose is pulled
Long Island, NY
Tuning nightmares? More like incompetent tuners. Real tuning nightmares are two computers fighting for control and melting your engine.
Simplicity is not what you need. You need something that can properly control the engine you want to build. If you can't tune it, you'll need to find someone who can tune it for you.
Agree 100% stay away from the alphabet soup of piggybacks!
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
Hey Jake i say we should slap one of those ebay elec suprachargers on the intake that would free up airflow to the turbo. You will be in the 700 hp range with no tuning. Hell i am shooting for a running supra right now.
Mello
12
CT
I put down between 660 and 713 rwhp on different dynos w/ a SP74 and all boost when I had my car. A stand alone will get you every ounce of power out of the car, but stock ecu w/ piggybacks can still make very serious numbers. My car just had pistons, arp hardware, HKS mhg and web cam cams w/ a standalone and 1000 cc inj.
The trick is keeping the car all together. I don't care what car you have, when you mod it this highly, stuff will break. I would recomend getting 1/2" head studs like the mkiv guys do, and getting 9:1 comp pistons for added power(although most will not agree w/ me).
And yes, it's a shame that the top guy on 7m never drove the car at that level. I have never ran lower than 31 psi after I got my car tuned untill I sold it. Why make all that power and never use it? I could have ran a 15:1 afr run once or 50 lbs on the dyno to make stupid numbers to brag about (like 90% of the mkiv guys). I should have left my car up on 7mpower instead of taking it down...
IHI-RHC7
"The Boss"
Oregon
You really get A Viper Kevin?
Jake, AEM EMS is the way to go. As far as simplicity goes, plug it in, tune.
But of course you want to switch to speed density, so you have to rewire for that.
The thing with EMS is that people think that you can plug it in and race. That is NOT the case. It took months to get my dad's supra to run like it should. But we were running a civic box because AEM didn't support us yet :( I've never seen a T88 spool like it does in his car though. On the street tuning on pump gas, pulling fuel in vaccum and adding timing aggressively to make the windmill turn gave us 21 psi by 4000 RPM. When we took it to the track, we went by the "shift when the power lets off" mentality. Looking back at the logs, that was 8400 rpm. With stock cams. It's ALL in the tune. Ron has been tuning his car conservitively for YEARS to keep his $4000 rods from dying. If you want to plug in a magic box and make 700 hp. It's not going to happen.
The thing I like about AEM is knock monitering. that way you can advance timing until knock, and back it off to be safe. There are so many failsafe features, like fuel automapping, knock control, EGT control. All of these things can save your motor. Or make it run like shit if you don't know how to utilize them. I suggest you get the AEM software, (it's free) and play around with it. Traction control, Nitrous control, Boost control, you name it. No piggy back comes close. And if all else fails, fly Sean McElderly out to tune it for you. He is the Man. Also, get a FFIM from Ron.
Mello
12
CT
No viper yet. It's nice being debt free at the moment :) I will pick one up over the winter. Waiting for that majic '99 blk on blk GTS or '02 yellow GTS w/ under 3K miles...
Mello
12
CT
PM'ed you. There is enough room. Surprised no one tried them either. That was one of the "secrets" on the last engine I was going to build...
figgie
Twin Cities, Minnesot-ah
i can answer the half inch stud question
at 12mm studs for our car STOCK. Our bolts/studs are already bigger than the MKIV (they use 10mm bolts).
going to 1/2" stud only increases the outside diameter by .03". Not that big a gain. Talking with ARP they actually recommend going bigger, two sizes bigger because of the required rethreading and retapping that needs to take place. Or in other words from 12mm to 14mm or 9/16 studs which is a significant upgrade in thickness :D
hope this helps
