Ok, 1.5JZ Swap 550cc Walbro Pump Single Turbo OEM Computer, SAFC, & Greddy BCC.
I was driving home from work yesterday and it stalled out on me when coming to a stop sign. I start it up it ran rough, and if i tap the gas lightly it started to move but then flooded and died. I've come to the conclusion it may be the TPS or MAP sensor, but I need help looking for diagrams to test both of these. Any help would be appriciated
PROBLEM FOUND & SOLVED: BAD CPS CONNECTOR AT REAR OF HEAD WITH BROKEN WIRE. FIX? BUY NEW CONNECTOR & WIRE AS ITS BROKEN RIGHT AT THE CONNECTOR HOUSING. I'm not in the mood to try and de-pin it.
