in comparisson to my 7M....hmmmm my 7M was pretty badass, when it was tuned it is/was faster than my 2J right now... But that's not telling the full story since my 2J isn't tuned and Ive only pushed it once, and that one push untuned felt about 90% of my 7M tuned....
My old 7M, FFI with 60-1 turbonetics, and the worksz
When tuning begins this engine will def be worth it...
Now to the monetary side of things.
Hardcharger is correct, do not buy a clip w/o a federal reserve.
Clip was ~3k, misc hoses alone = 200$, misc metal for fab ~ 200$,
Turbo another 1.5k, this stuff adds up. I did almost all the labor aside from the exhaust side of things, so i have shop fees on top of that, but it helps that i have known the shop tech/part owner since 3rd grade.
I would have never been able to do this swap when i was in college, but i did quite a bit to the 7M considering I was only making 12$/hr back then, but i also had my own business raking in 40$/hr every so often.
Now i graduated and the $$ side of things inst an issue, so i decided to do a swap people told me id never do, or just laughed off...
The swap will cost you lots of unexpected $$, headaches and time.
Back to the worth, is it worth it....... I would say yes, a 1j swap a 2j swap or even a 7M swap is well worth it if you will be better off than your current setup.... if my 7M didnt blow before i moved to nyc i would have returned to Tampa and just built on that, and bought a new car with the $$ i sunk into this project..... also you will never have everything you need when you start the swap.... i had a diff turbo, it hit the hood... so i had to buy a diff one lol.... the swap will test you mentally emotionally and def physically.....
i was def intimidated by the wiring alone, i called a few 2jz guys and they told me to just relax and just go for it.... so i did and that anxiety went away......
it's def a mental test (wiring wise) the rest is second nature if you have taken the 7M in and out mre than half a dozen times like I have.
I have a few more things to wrap up, but after that i will make time to do a write up while my memory is fresh..
-ian
