I need help on an HG choice.
casing
113
ottwa
ok.. i am doing my headgasket job soon. I only want to run BPU @ feul cut or so. I want a MHG but dont want to pull the motor. Should I just use the stock gasket?
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
IJ. said:
Always had good luck in the past with Felpro products but have never used their 7M gasket.
I had one, I was told by several people OEM was superior so I grabbed that instead, later someone told me the OEMs are Fel Pro made.. so no idea.
casing
113
ottwa
will all be the same if I get my head machined? cause i know you need a certain size MHG is it the same for the OEM?
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
My advice, check both head and block for flatness, if they are ok, have head machined, go to a dealer, get OEM gasket, I believe theres only one size for those. MHGs have 2 diff sizes usually.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Phoenix, are you talking about bore size or thickness, because there are lots of different thicknesses of mhgs...
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Whoops, I meant thickness, Ive only ever noticed 2 on the main market.. my bad lol 1.3 and 2mm? I forget, I know I see 2mm alot lol
suprarich
Guest
Nov 9, 2005
2,187
ohio
I used a felpro gasket on a few motors with good results. 425 rwhp with arp head bolts and ran for many years with no problems. The heads had been decked, the blocks cleaned and check for flatness only. One of the motors saw over 200 passes at the 1/4 mile with no BHG. I think the felpro with proper prep work is fine up to 400-450 hp. just my experience.
