I might sell my soul for Prosport Peak and Hold gauges
mk3forme
Lexington KY
yeah here is what mine looks like. I did it this way cause I dont want a guage on my dash not functioning, whether im actually looking at it or not. I dont have the balls to do a dash like Dave yet. Hopefully someday I will do something trick like that. Hopefully I will be so lucky for mine to turn out as nice. Dave Im not sure about running the NPT tap through the BSP hole. I know there is only a difference of one tooth. Ask IJ, he has probably tried it. Personally I would rather not take a chance and get an adaptor. Plus isnt your bottom end built? I would worry about metal shavings getting in the oil passages as well.
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
Allen i believe Dave wants to run a die on the sending unit, which would proably work as long as he uses teflon tape on it but i would just buy the adapter.:icon_bigg
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
mk3forme said:
Sorry John. If I would take the time to read thoroughly I would have seen the word DIE and not the word TAP:biglaugh: Reign here is where I got my adaptor from. They also have 1/8 BSP male with only 1 female 1/8 NPT. Mine has 3 and I only needed 2 but it came with a plug for the extra hole.
http://www.egauges.com/vdo_acce.asp?Subgroup=BSP_OTOD&Manf=All
Dont be sorry i am just trying to help.:icon_bigg
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
http://www.marlincrawler.com/images/vss_all_1000.jpg
MC-VSS
$59
Marlin Crawler VSS
We are now producing our very own Vechicle Speed Sensor (VSS). This 3-wire, 4-pluse magnetic pulse amplifier will convert ANY Toyota vehicle with a standard 22x1.50 mechanical speedometer drive to an electronic speedometer system. Features a standard Toyota VSS Plug for your convience. The Applications are unlimited, converting both 4WD and 2WD 22x1.50 mechanical speedometer setups to electronic 3-wire, 4-pulse speedometer setups. Now installing a Tacoma Engine into a Hilux or Land Cruiser is a snap! Works on both Gear and Chain Drive Transfercases!
For 1992-95 V6 Applications, when converting to a Gear Drive T/Case Setup, the only previous option was to use a 1992-95 Factory Toyota 4cyl 5-speed Gear Drive T/Case VSS, that sells for $210. The New Marlin Crawler VSS saves $150 on a 1992-95 V6 Transfercase Conversion.
:D
