I bought a welder today.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Came in a little over $400
Gas or Gasless.
Seems to have a lot of options.... now tell me about the terrible purchase I just made, and how I should have bought a Miller or Lincoln.
:rofl:
shaeff
Kurt is FTMFW x2!!!!
11
Around
that's pretty badass. let us know how well it works, and if it does you good, i'll probably pick one up! :)
-shaeff
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Works very well.
With only some short practice w/o GAS I made some decent looking beads.
I then went on to joining some 2.5"SS pipe... (Eh) heheh, I tried and only about 25% of the job looks good enough to use.
So I'm going to keep trying, then maybe get some gas and switch out the reel.
(I suggest investing in a angle grinder...:rofl:)
MK3Brent
Very expensive....
Aug 1, 2005
2,878
For those of you who are welders, and have used several types:
What is the real difference between the major name brands, and mine?
I've used Miller wire feed shielding gas welders before... and to me... a beginner, it's the same.
The mechanism inside all looks the same...if not identical.
Just curious that's all. :)
N
NDBoost
Guest
is the mechanism metal or plastic? Alot of the cheapoff companies use plastic components rather then metal.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
IJ. said:
Never tried gasless so can't offer any advice other then grab a can of antispatter and give the parts a good coat as this will make the finished job much prettier!
Maybe this is a "Guru- NO NO" but I just take the scraping brush to the welds after I'm done shooting them, and I think they look 10 times beter cleaned that way.
Spatter is definitely not hard with this stuff.
If you have a machined surface close by the spatter can actually weld itself there and the only way to shift it is with a grinder thus ruining the machined surface!
Just a heads up!
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Just a heads up!
I think I'd put the head facing down.... as not to get spatter on the machined surface.
