I <3 the sound of 45 psi of boost
Devin LeBlanc
1,830
Las Vegas NV.
Just finished up this evo at the shop. 2.0L 4G63, Manley A beam rods, JE High comp pistons, burschur Stage 3 built head, Cosworth Cams, Degree'd cams with Mivec on intake side and adjustable gear on exhaust side. Burschur HTA86 Turbo on a Burschur tubular manifold, ID2000 injectors, Burschur double pump system on E85. Car made 675 AWHP and 530AWTQ on 45 psi. This is on a eddy brake load dyno.
We got full boost under 5400 rpm's and spools a bit sooner on the street!! Incredible for a 2.0L As much as I love my supra, I really like Evo's!
[video=youtube;qXe2Iy8RhV0]http://www.youtube.com/watch?v=qXe2Iy8RhV0[/video]
Quick really shitty quality pull on the street on 37 lbs
[video=youtube;oohXLQVK6rg]http://www.youtube.com/watch?v=oohXLQVK6rg[/video]
te72
Classifieds Moderator
6,625
9
WHYoming
Was about to say, "675whp, that's it?" until I realized that's putting power to 4 wheels... not too shabby. Still remember seeing an Evo that Mynes in Mesa built a while back dyno, that thing was painful. :p
Devin LeBlanc
1,830
Las Vegas NV.
Yeah, Im really thinking about getting an Evo for another car. And the nice thing, the car is on Stock ECU with Tephramod V7, Speed density, No cat, no Evap/Smog equipment, E85, 3 Inch Straight pipe. Car had all smog monitors force passed with Tephramod. Car passed smog without any troubles, I couldn't believe it.
Ill post the video of the other Evo were re tuning soon. Waiting on a front diff, Last time It was on the dyno it did 848HP 711TQ to all 4 wheels @ 50 psi on a 6765. We just did new valve springs with 100 lbs on the seat @ the installed height and a .82 T4 Exhaust housing. Should be able to squeeze another 100WHP out of it!
te72
6,625
9
WHYoming
If I'm not mistaken, the stock ECU on these things is much like a GM ecu, or Honda, and as such are easy to tune by nature. Personally, I wouldn't mind one, but I think people would think I was nuts for RAISING the ride height, and sticking dirt tires on it, then attempting to out-dirty every truck in town. :p
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
IBoughtASupra;1786333 said:
With all the mods, when you check the ready monitors, are they ready? Any check engine light?
I doubt it, the evos ECU really is amazing. Theres so much stuff you can do with it theres almost no reason to go with EMS.
