How to replace water bypass hose #5
Oct 11, 2005
3,819
21
Thousand Oaks, CA
I cannot find any tool to reach in between the firewall and back of the head to get the hose clips off of water bypass hose #5. Anyone have any tips for doing this one?
PorterzSupra
703
Hebron CT
clip it with tin snips and or twist and pull till the clip breaks. Mine I was able to use the swivel arm and socket to loosen it
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I have a different method.
I pull the hose from the top - the one that goes to the firewall for the heater. Then put a BIG socket on the fitting that hose runs too and pull the whole fitting off. It's easy to get the hose off when you have the hose & fitting on your bench instead of on the car. :)
Oct 11, 2005
3,819
21
Thousand Oaks, CA
That's an interesting idea. I guess I'll need to get the two gaskets for the heater union. Any guesses as to the size of that fitting?
I'll jump in with a horror story using Grims method!
Way back when I got my Supra the previous owner hadn't ran coolant for some time so there was a lot of corrosion in the steel fittings and pipe and most of the rubber was perished or cracking.
I decided to replace as much as I could without pulling the motor, I got to "That Fitting" put a big socket on it had to pull fairly hard and of course it snapped off!
Out came the motor, I found a really cool tool that's a 1/2" square taper with machined edges that removed the broken part no problems.
While it was out I chucked a set of rings and bearings in and did another 100.000 km's before the erroded head caused a BHG then it all began! ;)
