How much power
Supra Sound
Supra Newbie
Jul 24, 2005
51
Stafford VA
How much power will a 3" exhaust, downpipe ,and boost controller set at 8 psi roughly give me on my 90 turbo automatic?
Thanks in advance
americanjebus
Mr. Evergreen
wa.
stock auto in great shape got me 190 wheel hp. it makes sense considering you lose 40 hp through the transmission
i did 4 runs with g-timer tuned to perfection and i got 190, 191, 189, and 190 hp readings.
with those mods probabbly something like 230-240 to the wheels. and maybe somthing like 270 crank.
automatics put down less hp than manuals but we put down more torque.
aye mate
Hiatus over.
Maryland
you dont need a bc for 8psi. When I got full exhaust, fipk, and my pvc pipes I maxed out the stock gauge with no boost manipulation.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Power is calculated based on torque, you can't put down more torque without putting down more power. If you put down less power, you put down less torque.
Unless of course you mean by gearing, in which case you can have higher torque at the same power, but speed will be lower.
americanjebus
Mr. Evergreen
wa.
all i remember is seeing the numbers on the old forum of a comparison of the auto vs the 5sp and the 5spd lost 15 -20 hp through the gears and the auto lost 40 in hp but on the numbers the torque # was higher on the auto then it was on the 5sp. so yea what orion said.
Loki
The Future is Unwritten
Prince George, B.C.
I maxed out my stock boost gauge with an fipk and Divorced DP :biglaugh:
siman
Lifetime Ban
Murfreesboro, TN
after I get my new o2 sensor ( new egt gauge too) , n/a cams, and the S-AFC and two more washers on my motor I am ( and my father too) going get my car dyno'd at a dyno jet within a month or so....aiming for 16lbs of boost...350ish to the wheels.
-Jonathan
robbo185
693
Chicago
gotboost?mk3 said:
well what about intake,exhaust, lexus afm and 550ccs at 11 psi. that will be my setup in about 2 weeks
we could give guess-timations all day
just go to the dyno. If you got the money for those mods...another 50 bucks wont hurt you too much
D
doodoobrova
Guest
Damn, I don't have a dyno around here. I have to drive to redneck town where all the Mustangs and shitty Camaro's inhabit, Biflo County.
Can anyone give me a basic wheel HP estimate on my Auto 91 Turbo with the downpipe, exhaust and intake? That would be sweet, thanks again guys.
