how much boost on stock head gasket?
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
how much boost can you run on a stock untourqed head gasket, if you tourqe it how much boost can you run, everything is stock minus bov and ct26 with to4e wheel, what do you tourqe the head to anyway?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Correct about the section. Thread moved.
bowtiebuba, not much. Original gasket with oem torque on it will more than likely blow up at stock boost levels, never mind the upgraded turbo.
If you torque it AND it survives, you can run something less than 20 psi... because that is where mine went south.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
A friend of mine was running 15psi on a stock hg torqued to 75 pounds... It didnt last long... About 2 or 3 months... But he knew it would go and was prepared to replace it... So long as you're ready, boost up...
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
what about the boost cut, i heard theses cars have a boost cut in the computor at 15 psi or somethin, how much boost can i run on stock injectors/fuel system as well
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Now you're getting complicated. The stock ECU will cut at about 11-13psi, depending - every one appears to be somewhat different. There are various methods around this, the most common being the lexus AFM + 550cc injectors, and the most recent being the MAFT.
Stock injectors are good to over 400 rwhp.
Stock fuel system? Tough call... and I'm not exactly certain yet.
S
Slow Poopra 7MGTE
Guest
re torque it, keep detonation down and tune it well and it should be fine
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
bowtiebuba said:
lol im sure i will, is the boost cut the fuel cut or are they 2 totallty diffrent things
Hrm... I'm not entirely certain anymore. Once upon a time I was certain it was just ignition cut, but I've heard the ECU has an output to the fuel pump relay, so it could easily cut both at once...
mullenc525
33
If the ecu is cutting fuel, I very much doubt it would do it using the fuel pump relay. That would make it very easy to make a FCD. Also, the motor would run lean as the fuel pressure dropped away and then would slowly start to run again as the FP picked up. If it cuts fuel I am sure it does it by cutting the duty cycle.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Err... what I meant is that I'm pretty certain it cuts both fuel and spark. I'm absolutely certain that it cuts spark, and I'm pretty sure it cuts back fuel as well.
However, I'm perfectly willing to be proven wrong on either point.
