how many peoepl have a slight miss on there supra aka the fart or the cough
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i ahve all wasy had one on mine piss's me off both car int he matter of fact
i all ready knwo one fo my coisl must be bad cause thsi si just guess thou btu certon of it but again i ave yet to test it lol \
but how many peopel have the fart akak cugh wheil idealing
BJ91T
810
Baton Rouge LA
mine wont spudder unless i give it a rev then it wants to idle at 400 rpm for a sec and or die No idea what is going on with it. Also unless i cruise and boost it for about 5-10 minites it will die when brought back to idle
BJ91T
810
Baton Rouge LA
any info on mine??? It will throw a random CEL when it is doing the stubborness but it always goes away before i check it Not sure whats up the CEL goes away when i start driving. i have no idea its bothersome though
EDIT: my simptoms posted above ^^ a few posts ago
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
mine does sometimes when i drive it hard then let it idle for a sec itll spit like once or twice.
when its runnin like shit itll choke itself when you rev it like if i havnt driven it for 2-3 weeks and go to drive it itll run like shit and miss and choke but once it gets goin its fine.
i do however need plugs and wires.
other than that shes smooth as glass at idle.
Satan
Tampa
...alot of stuff can contribute to or cause that.
In addition to what's been mentioned, here's a list of what I've seen fix it....
1. Replacing the EGR gasket at the head
2. Replacing MAF
3. Cleaning out the spark plug valley REALLY good (removing years of gunk).
4. Basically ANYTHING that touches the EFI system
bgrieger
Toronto
in 10 years I haven't got rid of it and almost everything has been replaced at least once. I jokingly tell people who ask that it's a hardcore lumpy cam. Every 7M I've seen seems to do it on stock electronics. A couple of standalone users I know don't have it anymore, and even there a couple still do.
staticpat
Supra Chair!
Birmingham, AL
I've always had a little burp or pop every few seconds at idle. I don't think you notice it much until you get an exhaust. Anything above idle though and it goes away instantly. Never bothered me enough, and I've heard many people say its common.
lagged
1991 1JZ
new rochelle
all the 7ms i had did it. one jdm 7m, and 2 rebuilds always had a slight irregular miss at idle.
in my opinion id say it was MOST LIKELY the coilpacks i was using. everything on these cars is old. some parts can still work pretty well but have little quirks making small misses very hard to track down.
jetjock
creepy-ass cracka
9,439
It may be typical these days but it's not normal. One of the things that impressed me about the car when I bought it was how smoothly it idled. You could've stood a coin on edge. The last car I worked on, one saved from the junkyard with a JDM engine later installed, idles nearly as well because I went completely through it after replacing the HG.
While there are many causes behind misfire the trick is first finding out which cylinder(s) are involved. An ignition scope will quickly pinpoint that or rule out the ignition system altogether. Scoping the O2 sensor while triggering off IGt is another way to see who's at fault. So is measuring exhaust pulsations. Larger misfires can be found by using an IR thermometer on the exhaust manifold. Using smoke on the engine is also very helpful. Once the cylinder is identified it's a lot easier to track the problem down. Often the cause is mechanical ie; pirate air, valve clearance, poor valve sealing, deposits, ect. That was the case in the few times I've come across it. The EFI system is rarely the culprit behind any problem on these cars as long as it's been maintained and not been screwed with by those who don't understand how it works.
Since by law OBD-II is so much better at ferreting out misfire it's a pity we don't have it. That said the ecu in the 7M can do it, it just needs to happen under certain conditions and even then it's not very accurate. The code involved is 25. OBD-II looks at the speed of the NE signal just after ignition. It's a much more sensitive method of detecting misfire. That said the causes behind it are the same in any engine.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
mine whould do that when it started to get to rich, it would miss and do what your saying, sounded a bit different when she lean out a bit.
i guess there's my .02
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
my car did it for a day, if i started to boost hard it would begin to miss.
all it needed was the old GReddy spark plugs pulled and some new OEM ones from toyota to get it running silky smooth again :)
