How does Coolant get in Oil in the 7MGTE?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
kaiser;1940175 said:
This I did not know, I just hammered it in with some FIPG around the edges.
How does one center peen?
I took pics of How I installed it, will post tonight after work
Sounds like this could be the problem, that front welsh plug is a bitch. The front plug is a special type of welsh plug which is close to the same diameter of the hole in the block. Once you put it in place you need to dimple the center of the plug which makes the outer diameter expand and make a tight fit into the block. Its best to let a machine shop do this, because if you dent it in too far you will reduce the size of the plug again and it could pop out. Also make sure you use a good quality plug, I wouldn't use anything besides an OEM plug installed by someone who really knows what they are doing and have done these before. You probably need to do a complete teardown at this point considering all the water that got in the oil.
8,897
jetjock;1940352 said:
That's a lot like Dextron :icon_razz
It is even funnier when a "GM World Class Technician" call is Dextron. But to be fair, that just means he is also certified in body shop. As though people that pull dents and paint also work on things that use hexidecimal language. The guy is kind of a riot with things he says.
kaiser
96
Thunder Bay
Aww Hell, so do I need to pull everything apart and rinse it all off with brake cleaner then re assemble or do I need new bearings.
ATL88Supra;1940350 said:
if you have coolant in the oil the build is already fucked so why bother asking
Wow, super useful dick. Way to chime in with some helpful information. Maybe I am asking so I can get an answer so others can read this and avoid the mistake.
ANYWAY. I understand that now I must at the bare minimum clean all the bearing surfaces.
This motor is not in a supra but a Toyota Pickup and I cannot pull just the block I must pull both block and tranny together. This is not really an option as I have moved to a new town for work and do not have access to a garage with a cherry picker (not sure what you all call them but i am talking about one of these)
So I am Kind of limited to dropping the pan and pulling the head.
Now before someone hops on there high horse and tells me not to be lazy and to pull the motor, understand that I cannot. if I could I would but I can't.
I realize this will greatly affect the longevity of my motor but I can rebuild it in a year or so when I get a house.
Now that this is under stood, what are my options?
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
You can redo anything in the head with the motor in situ but if you need to do freeze plugs in the block over again I don't think you can fix that in car. Have you determined what exactly needs fixing?
I'd pay a good shop to do it right or find a garage for rent and buy a hoist.
Sent from my Galaxy Nexus using Tapatalk 2
kaiser
96
Thunder Bay
I am pretty sure it must be mis-instillation of this freeze plug
What exactly would I be paying a shop to do. Noone has answered that. Do I simply need to pull the crank and clean the journals of milky oil?
This motor has NEVER been road driven and its cumulative run time is less then 30 min. Do I REALLY need to rebuild the bottom end or just flush the bottom end?
Another MkIII
697
Chicago
Without making assumptions, at the minimum you need to remove and inspect the bearings. Check the clearances, and if they are bad, replace them. Pull the head, disassemble and clean everything. You might get away with that.
-AM3
Bmettie
188
Florida
Is it just me or is it in backwards? It looks like it is in the pic.
"Hump" of the plug should be facing out when installed, then center peened (hammered)
Supracentral
10
-AM3
The operative word being might.
This kind of contamination is a death sentence for a motor.
kaiser
96
Thunder Bay
It is for sure in backwards, That is the mis-installation I did. I had never encountered a freeze plug like that before.
gats
Rebuilding... Slowly!
Mar 3, 2009
182
Sydney, NSW
I think it has been installed backwards.
Pic of my original block for reference...
jake8790
Life's too short for N/A
Dec 18, 2011
395
Oregon
I would go ahead and disassemble and hot tank everything and get the block surfaced properly for a MHG while you're at it. Replace the bearings. If you don't have the means to pull the engine right now, I would call the project off until you can do it right. I know it's not what you want to hear, but it would suck even more to put it all back together after fixing the freeze plug and then develop rod knock.
ATL88Supra
The Asshole
Jun 22, 2007
497
Atlanta, Georgia, United States
I am a dick for telling you how it is OK guess so first off coolant that mixes with oil becomes acid and right now that acid is eating away at every soft metal in that motor that's why the build is fucked. you have to start over to try and save it at this point would cost you more in the longrun
8,897
For future refrence....you can take the oil pump bearings and plugs to the machine shop with the pistons and they can do that for you. Correctly.
kaiser
96
Thunder Bay
There are no Machine shops capable of doing a MHG decking for 3 hours. Problem with living in Rural Canada. I see the problem with the acidic Coolant. This blows. Ok, Well I will pull the oil pan off and clean it. Then pull the bearings. If they have any hint of scoring or discoloration I will have to change them. I know its the right thing to do but I dont have a clean indoor area with a flat floor to do it. It would take me 3 weeks because I am out of town working 5 days a week. So a weekend to pull it, a weekend to re build it and a weekend to put it back in. FML
ATL88Supra
The Asshole
Jun 22, 2007
497
you are missing the point, you need to hot tank it now cause that acid is all over the block and head now, you could change the oil 20 times and it will still have traces of it, spend the extra time drive 3 hrs if you have to or pick a different motor for your truck
you don't play with fate on a 7mgte
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
To pull the pan I assume you'll take out the motor, right? At that point you should really drive it out to a machinist to have it cleaned and get the plugs and oil pump bearing installed correctly. This stuff is cheap to have done and is well worth the 12 hours in drive time there and back. You can also have them prep it for MHG and have a stout motor.
I just don't see this going well if u do it on your own on a dirty floor. I mean that in no way be offensive or personal. Its a performance engine in a performance car. Time to treat it like one. :)
The time and convenience you could save now will be greatly outweighed if the motor needs another rebuild in a few months.
