How does Coolant get in Oil in the 7MGTE?
kaiser
96
Thunder Bay
Ok. I am Getting MASSIVE amounts of coolant in my oil. So much that my oil system is getting extra pressure from my coolant circuit.
So I need to thing of the possible Entry Points of coolant into the lubrication system.
-Head Gasket
-Turbo
-Cracked Block/Head
Supracentral
12
Headgasket blown between the water jacket and cylinders is most common.
Is it pumping coolant out the overflow too?
kaiser
96
Thunder Bay
Another MkIII;1940023 said:
My money is on a BHG.
-AM3
My Build Thread
This is a freshly magnafluxed and rebuilt Block with:
-JE Pistons
- New Bearings (20 over i think)
-ARP Everything
-1.3 MHG
-All new seals & Gaskets
-Walbro 255
-AEM FPR
- AN Fuel lines -8 sending -6 return
- Shimmed new oil pump and new oil squirters
-PnP Head
- Comp Cams Valve Springs
- new valve guides
-3 angle valve job
I had the Head, Block and rear timing cover decked at a machine shop.
There was some question about the RA of the decking being adequate for the MHG so I remove it this long weekend (2 days ago at time of writing) and Replaced it with an OEM HG.
Would failing to apply this sealant correctly
cause coolant to push into the oil?
When the oil pressure spiked it blew this seal. This is what my oil looks like.
I need help guys. About ready to burn the whole project.
NewAgeMA70
4
Maybe pressurize the cooling system with air and try to listen to where it seems to be comming from. Did you machine the timing cover with the block....?
Sent from my SCH-I510 using Tapatalk 2
Beals
JZA70 TT-R
Feb 3, 2009
592
Alberta, Canada
If your head was machined down for the metal gasket I would not switch it out for an OEM one to keep your compression even. But if you have a blown frost plug your going to loose coolant everywhere. This is quite perticular, I would take it back to the shop that did the work and have them check it over sounds like their work was questionable. Turbo wouldn't push coolant into your oil but if it's blown it could blowing oil everywhere and in turn if you had a open frost plug it could mix then.
edit: and who is the chick in your avatar :p
kaiser
96
Thunder Bay
Rear Timing cover was machined. Pressurized the system today, wont hold any pressure.
jake8790;1940058 said:
No. Oil leak.
Freeze plug behind timing cover?
When I first assembled the block this was forgotten. I have since pulled the rear timing cover and installed it with black FIPG around the edges. Any chance it could have pushed itself out?
I assembled it. Fail on my part
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
How did you install it? It needs to be put in place and the center peened in to expand the plug/
He keeps skipping over the important question................who is in your avatar? She looks like Katie Perry to me.
Another MkIII
697
Chicago
Do the following tests:
Coolant system pressure test
Compression test
Cylinder leakdown test
These should help you narrow it down. My money is still on the head gasket.
-AM3
8,900
I saw a tech install a headgasket upside down once. It almost fit perfect and he just didn't notice. He was good at his job. It can happen to anybody. Almost everything lined up and it wasn't noticed. Until he started it and got to redo it for free.
  • Wow
Reactions: loc182
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
jetjock;1940128 said:
^ Except around here we have people building engines who've never done it before with predictable results.
While I agree there are people doing things that can be avoided, I think it's important to realize one of the best ways to learn the right way is by feeling the pain of the wrong way. Nobody's an expert their first time around.
  • Love
Reactions: loc182
kaiser
96
Thunder Bay
This I did not know, I just hammered it in with some FIPG around the edges.
How does one center peen?
I took pics of How I installed it, will post tonight after work
