how big?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
For NA 255 or a little bigger if you can find them. Turbo. I have seen tires in the 300's on there. But nicely fit I would say 275 maybe 295 for the biggest.
Do you know how wide the wheels are? I don't remember what the stock wheels came, but your local tire dealer will let you know, and I'm sure Boris and a few others know also.
EDIT: Told you so.
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
EDIT: Told you so.
i got 275's on mine the rear wheels are 10.5" wide. shouldnt you be able to fit 315's?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
need new tires;900761 said:
n/a mk4 = 16x8 front 16x9 rear
mk4 tt= 17x8 front 17x9.5 rear
iirc the mk4 tt fronts are 17.8 but not 110%. otherwise i am sure
Yup right. and +50 offset all around
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
I promise, they are 17x8 and 17x9.5, stock... as that that is what is stamped in the sides of my rims... :D
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
FYI...there are no 295's in 17" tires. Big gap from 285/40's, up to 315's! You can mount a 315 on a 9.5" rim, but it is not recommended. A seriously high hp car could break the bead, and spin the rim inside the tire! Not good!:nono::biglaugh:
