Hey all.
Because of my dreams of a high reving NA engine, i had to either buy og build a new and ligther flywheel.
Also i had to find a stronger clutch so here is what happend.
I made some drawing of the flywheel, and using the solidworks 2008 program i also could calculate the weight of it
The flywheel is made of steel 52, strong steel that is used for that kind of things.
And then the cnc machine was started
The clutch is a tilton racing clutch with to cinter metallic plates, and it can handle up to 950nm.....so i think it will do
Here is some pic
Host Images with PicTiger
The flywheel incl the clutch is heavy standard.....17kg
This new one incl all.. 8.6kg
I think it will rev fast
Of course i will loose some of my tourque.....but i build for high rpm so f.ck that
Here is some pic
