HKS MHG vs. Cometic
topgear
The Thrillseeker.
Jun 4, 2007
80
Tallinn
last time did have a BHG (caused by detonation) on a HKS 1.2mm with 472whp.
Fixed the problem that caused detonation and going for a 600whp and not shure what to use, have this HKS 1.2mm and 3.0mm Cometic
which is better for the job ?
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Well our Estonian friend here can decide. ;)
Topgear: Just make sure you read the link i've provided and calculate your base compression ratio, and decide.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
In my experience, HKS is much tougher than Cometic. I've blown a Cometic without causing any damage to the internals... and I've blown apart some pistons trying to kill an HKS. So, it looks as if:
HKS > Stock Toyota pistons > Cometic.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
I'd agree with that, but the Cometic is a pretty decent HG.
Hey Grim...How much boost were you pushing when you blew the Cometic, or was it something else that contributed to the BHG?
Given a decent tune and stock compression, how much boost do you think the cometic can handle? I've known of people running 17 or 18 lbs of boost on them with no problems (as far as I could tell).
Reason I ask is I'm currently running the Cometic with good results, but I'm not pushing huge boost (91 octane is about all you can get in SoCal). Kinda limits what one can do without detonating...and race gas on my dd is not going to happen.
I ran 30psi on a cometic no problems at all until I leaned it out and ran out of IC capacity during a long uphill pull.
I've also popped a couple of Stoppers during fuel system development
(1 when I blew the intake up between 3 cylinders)
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
I'm reasonably certain that it was heat that blew the Cometic. I lost a coolant line, then lost my coolant, and the engine compartment was REALLY hot. When I pulled the Cometic, it was snapped in between all the cylinders. I put another HKS back in and it's been running fine ever since.
topgear
The Thrillseeker.
Jun 4, 2007
80
Tallinn
going to use HKS
from now on I`m afraid of using Cometic
didnt thought to buy stopper:aigo:
the reason of using 1.2mm HKS is allso to have good pull while boost lag (using gt40 turbo)
thanks to all of you for advices
Ummm...if you raise cylinder compression with a thinner MHG and you run high boost = BOOM!
I would stay with stock thickness (accounting for material removed from the block/head decks).
Cometic makes a good MHG...it's all in the prep and torquing it down correctly. The Stopper is the best though.
topgear
The Thrillseeker.
Jun 4, 2007
80
Tallinn
So,
I had HKS 1,2mm and had 520whp, then had fuel problems and engine gone.
Got new one, bought titan motorsport 2.0mm hg and blew it in a week, changed it to 2.0mm hks bead
now it is 2 years since then, car is still in everyday use, has 505whp map, still working like swits clock.
suprarich
Guest
Nov 9, 2005
2,187
ohio
I have motors over 1000 hp on both the cometic and the hks gaskets with out problems. It is all in the prep and tune.
