High pressure power steering lines, What is required?
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
I'm trying to plan out my power steering system. I know that the line from the pump to the rack will see high psi, so I'll need lines capable of the task.
My question is the lines from the rack -> cooler -> resevoir, I assume that these lines will see significantly less pressure so I can use regular oil lines capable of 350psi. Is my assumption correct?
7EMPIRE
175
Raliegh
i would say that seems about right.my moms high pressure line on her 89 had a small leak, so i priced out all new hoses.the high pressure hose was 60$
and the other 2 were 25$,that lead me to believe the other two lines werent as heavy duty as the "high pressure line"
To back up JJ I use standard Oil proof low pressure hose on the return there's very little pressure in there.
(My PWR Steer filter has a plastic body and it's installed in the return)
