Help with swapping in a 89+ Motor with grey plug harness into a 88
SC61 MK3
316
FL
The plan is to swap the motor out of my 1990 Turbo with the gray plug harness into a 1988 Turbo car with the yellow plug harness. What would be the easiest way of doing this? Can I use the yellow plug harness on my 90 motor or do I have to rewire the entire car for the gray plug harness?
spinyard
always lurking..
Nov 1, 2009
49
Ottawa
Did this last year. I have a 86.5 car with a 87 harness. the motor is a 92. The only plugs that are different are the thermostat housing sensors. so just use the old housing, or swap out the individual sensors.
shaeff
Kurt is FTMFW x2!!!!
9
Around
Use the yellow plug harness on the motor. ALWAYS use the harness that matches the CHASSIS of the car! That being said, you have a few options for the very few connectors that won't match up because of the newer motor w/ older harness.
1) just swap the sensors. That's the easiest way
2) De-pin the harness connectors and swap the connectors to the yellow harness.
Yep. :)
SC61 MK3
316
FL
What ever engine harness originally came with the car you need that harness and ecu unless you want to rewire the entire car.
For example I parted out my 90 turbo and took out the 90 motor/gray harness/gray ecu. I ended up buying a 88 turbo shell and I used my 7mgte from my 1990 but had to get a yellow plug 7mgte harness and ecu so it plugged into the car and I didn't have to spend a shit load of time trying to figure out where every wire goes and rig up the entire car, not worth it imo
---------- Post added at 10:45 PM ---------- Previous post was at 10:43 PM ----------
A engine harness and ecu for an 87/88 is cheap, look around. The gray plug stuff is worth more you can sell the 89+ stuff and just buy the correct 88 yellow plug stuff and have left over money
shaeff
9
Around
Volvospy;1681642 said:
I believe the camshaft position sensor's clips are different. Be careful when swapping the clips!
No they aren't.
