help, no start after replacing HG
Skadaloz
32
Ephrata,PA
like title says...i just replace my head and headgasket, cranks but no start....cranks freely like no combustion happening...fuel pressure is at 25-30 psi key on....has spark but looks weak....any clues would help
dbsupra90
toonar
indiucky
holy crap that could be anything.
check codes of course.
first thing i would look at (aside from goofy things like plug wires in wrong order, something not plugged in, etc) is make sure the cps is aligned properly. it's real easy to align it wrong.
kotu100
1,899
Easton, Ma
your timing is off.
make sure you crank and cam gear timing marks are line up.
and if you took the cam gears off make sure both the pins are in the middle holes on both the gear and the shaft itself.
ilovemysupra
51
Melrose, MN
kotu100;1300770 said:
your timing is off.
most likely
Skadaloz
32
Ephrata,PA
your timing is off.
i recheck timing and timing marks are all lined up
i know you can use a paper clip to jump the thingy but do you know the exact pin to jump?
rayall01
901
Westfield, ma
Skadaloz;1301547 said:
ahah i just search after i posted and found it...and as for the cps i put it back to the same position b4 i took it off(i marked it)
When you marked it, was the #1 piston at compression TDC?
Skadaloz
32
Ephrata,PA
mkiiSupraMan18;1301554 said:
No combustion meaning.... not 'trying to start' but turning over or 'its turning really fast and nothing is happening'
cranks a little faster than normal but nothing happens
i dont think it was...i wonder if i did my timing wrong, meaning #1 piston at TDC but on power stroke instead of intake stroke? would it even matter
Skadaloz
32
Ephrata,PA
mkiiSupraMan18;1302224 said:
^ would backfire like a mo-fo, you'd know if that was the case.
then nope i got it right then...but still no start...well i have to recharge my batter b/c after so many cranking its dead...dash lights just turns on and trickle and dies
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
i don't care how much you "marked" the cps position. Did you re-install it as per the TSRM specs? If not, re-adjust and get back to us if your problem persists.
Skadaloz
32
Ephrata,PA
ill get bak to you on that
well anywais i just check my check engine light and this is wat i got
blink..blink.....blink..blink.....blink..blink.....blink..blink..blink..blink and repeat
so is it code 22 and 24?
dbsupra90
toonar
indiucky
22 = water temp sensor. either not plugged in correctly or the sensor is bad. wouldnt cause the car not to start.
24 = intake air temp sensor. you running the stock afm?
Skadaloz
32
Ephrata,PA
i repostion the cps as per the TRSM specs and still no start
got it...code 24 was poping up b/c i unplugged the afm and the water temp sensor wires were corroded and i touch it and it fell off so i rewire it and now no codes but still no start...sounds like it wants to start but then goes back to crankin fast...well ima do a compression test tommarow n see who things goes...and ill redo the cps and the timing again for the 4th time:icon_mad:
7mgte1988
7M-Runner
Sep 22, 2008
223
Orlando
I might be wrong but i hade this same problem 2 months ago but mine was the wires from the CPS. i had to wiggled the wires and have someone start the car and it will turn over.
Skadaloz
32
Ephrata,PA
ill give that a shot since half of the male plug are broken in half an showing the pins
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Why would you even be trying to have us diagnose your car without having simple stuff like that fixed first?
I'm going to start giving half-assed answers as it seems most looking for support tend to half-ass their own work.
