Help identifying cat back pls
tysen
26
muskoka
Hi, looking for help identifying this cat back. looks little larger than 3". has a number on a little brace off the muffler, says 8f691. Any insight would be great, I hope the pics work. cheers
91Supra313
1,062
Clarksville TN
#04;1939868 said:
is that a purple-ish plating on the pipes? Apexi likes to use that shit....
Look a bit more like rust to me. Not only that but there would be Apexi stamped on the tip. Same with a Blitz NuR spec. Those are two unmistakable marks
JDMMA70
2,550
Houston
That canister looks similar to the ones found on ebay, cx racing cat backs. Only this one has a resonator.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
The size of the picture sucks, but the shape and way the piping routes, it almost looks like a HKS Hi-Power. Does it have a 4 bolt flange between the mid-pipe and muffler? Also on the muffler, on either side of the tip, should say "HKS" on one side and "Hi Power Muffler" on the other.
91Supra313
1,062
Clarksville TN
Not to sound like a dick here Moy but if it said that.....I doubt he would have made this thread.
OP- Most of the higher dollar exhausts ie; HKS, Blitz, Apexi, even Megan, usually have the names stamped somewhere on the muffler. If there is nothing on it, chances are it is a ebay knock-off.
91Supra313
1,062
Clarksville TN
If you have been to the exhaust to look at it again, you should have gotten a much larger pic of it. Then this problem would have been solved already. We can all guess for another few weeks, but until you get a larger pic, this is a useless game.
