I'm going to install a Titan hg soon, and I'm wondering about coating it before installation. Titan doesn't reccommend it, but has anyone on here done any precoating before install? ty
mustangman05 said:i like to use brake quiet spray from permatex on my hg's
jdub said:If it's a composite or used MHG, that's fine...on a new MHG, no way. Every MHG maker specifically recommends against it due to what I said above.
You must spread some Reputation around before giving it to jdub again.
suprarich said:Where do we get what info? All I was doing was agreeing that additional sealer is not needed. The viton is plenty if the block and head are prepared correctly. If your gong to skimp on the RA then by all means, spray on the lazy. :biglaugh:
jdub said:Well...here's one:
http://www.aa1car.com/library/2003/eb30320.htm
And here's another:
http://www.babcox.com/editorial/ar/eb70228.htm
Note this part under Installation Issues:
"Another installer error is using a sealer on a coated composition head gasket. "Some sealers will react with the gasket coating and turn it into goo," claims McKnight. "Our philosophy with Victor-Reinz gaskets is if a gasket requires a sealer, we will include it with the gasket. If no sealer comes with the gasket, it doesn’t need any, and no sealer should be used."
Key words: "Installer error"
Every manufacturer...all of them...say the coating of Vitron is put there to make the initial seal. And all of them have an RA spec to make sure that seal happens. The RA and the torque spec on the bolts or studs is the driving factor on ensuring a MHG seals...using spray to make up for not resurfacing the block is NOT recommended by ANY manufacturer.
The companies that make the MHGs have engineers that are pretty smart about this stuff. I will trust them over any hearsay on this forum...every time. You can use the spray if you want...if you recommend it here, you should also point out that it is not the way the manufacture intended the MHG to be installed.
Arron...I'm sure you know what you are doing. This may be a "pet peeve" you want to re-think.
bigaaron said:The RA on our blocks and heads is better then most shops can even do with their equipment. <7 RA.
I'm not getting on you about it personally, I'm just stating my experience. This is one of the "unsubstantiated rumors" that are on my pet peeve list, so sorry if I get all huffy about it. LOL You're right, it is not needed, but it seems to help and I have not seen any ill effects.
CryoSlash said:aaron knows his shit. the two people i would trust with building 7m's is him and jeff (jtamulis)... they've probabyl built more 7m's on here then anyone else. successful 7m's to add!
bigaaron said:Using a "victor reinz" metal headgasket might be something you would want to rethink. Also, "some sealers" does not apply to Permatex copper spray with a HKS metal headgasket, I am sure of that. I had a HKS stopper mhg blow on the first engine I build for myself a long time back when I first got into the 7m. The sealing layer just looked very very thin. It seeped pressure into the cooling system. There is sometimes some slight erosion that occurs around the cooling passages that the surfacing does not completely remove, and also something that looks like imperfections in the original casting on many blocks. There are many things on a 7m engine that you will make you learn to take standard engine building advice with a grain of salt. I've had to insist on several things that most machine shops will tell you is not necessary.
jdub said:Ok...from the Cometic site:
"Check your dowel pins as they register the gasket and head into proper location. Replace worn or damaged dowels. The gasket mating
surfaces must be smooth 50RA or finer. Additional sealer is not required with Cometic MLS Head Gaskets. The outer layers of the
gasket are coated with a .001" thick coating of viton (a high temperature flouroelastomer)."
Why would cometic say that? If the sealer assisted in the seal, wouldn't Cometic reduce their complaints if that DID recommend it?
Show me a manufacturer that recommends a sealer be used and I will shut-up
suprarich said:This is my take on it. I have seen people try to use copperspray and permatex as a lazy way out. They think they can skip out on some prep work if they just swab on the sealer. Anytime we post about using an additional sealer other than the viton it should be stressed that it is not for getting out of all the work involved in preping the head and the block. If you can get the block perfect with out casting pinholes, and the head a mirror. Then I think the viton alone is enough. If the block after being prepared shows porousity and corrosion marks, then maybe an additional sealer should be used.
