bigaaron said:
I'm not disagreeing with you that it is not needed, and I appreciate the mutual respect we share.
Thank you...Arron your ability to build a solid 7M is without question. I would not recommend you if I thought otherwise. Being able to machine down to a sub-7 RA spec is amazing
And is a testment to your attention to detail.
bigaaron said:
I think .001 is just not a thick enough viton coating for the 7m in particular. Their recommendations would probably hold true for 99% of the headgaskets they make, but we all know the 7m kinda defies logic on certain levels.
If you know what you are doing...a very thin layer of copper spray will likely not cause a problem...still the manufacturers do not recommend it. My thoughts are against recommending it...especially here. That is due to a 1st time builder getting the "more is better" syndrome...you put very much copper spray on a new MHG and the viton is toast....it will turn into goo and compromise both the viton and the copper.
I honestly believe your success in building a 7M stems from the attention to detail in exceeding the RA spec for the head/block and using the proper torque for the fastner used. MHG's are very picky concerning the surface...they seal because of the smoothness between surfaces. To be honest...with your attention to detail...you could never use copper spray again and get the same results you do now.
bigaaron said:
Remember that Cometic sells gaskets with rivets in them that will cause a major failure if not removed by the customer. That = poor design in my book. People misinterpreted the 50 RA as meaning the Cometic headgaskets are "more forgiving", yet there have been several blown Cometic MHG's recently because of that misinformation. If they are more forgiving then who needs to surface the deck..... OH No!
Ahhh...the famous rivet. I agree with you...it's a cost saving technique Cometic uses to keep their MHG's together until they are installed. The "forgiving" part is a misnomer...it's only in the sense that the RA is greater than an HKS MHG RA of 30. The RA spec still should be met for the Cometic (or any other MHG for that matter).
And I do like have a good discussion...makes keeping sharp on this stuff a lot more enjoyable :icon_bigg
